Moin,
there are still some bugs left on the 2.4 milestone and I would like to
comment on them, perhaps raising some interest here:
78265 Add support for ICC color profiles
I am currently finishing the remaining bits. Since last night the
color-managed display actually does the right thing. There are
still some things left to be done in the lcms plug-in though.
156905 GimpAspectPreview doesn't respect the layer offset and ca...
I believe that this one can be fixed using the existing API. We
should definitely try to fix it in 2.4 but it doesn't need to
block the release.
349340 Alt behaves incorrectly for new rectangle/ellipse selecti...
Should probably be looked at. We should get the interaction right
for the 2.4 release and not change it later unless absolutely needed.
355545 fixing the aspect ratio for crop tool
As fas as I know Martin is working on this and expects to have it
ready soon.
356716 GimpZoomPreview is broken in some plug-ins
There are two more plug-ins that need to be fixed. Probably some low
hanging fruits...
360106 GimpPdbDialog appears behind plug-in dialogs
I still don't know how to best address this one. Perhaps set the
stay-on-top flag on the PDB dialogs. That would be ugly though.
374854 possible optimizations in Script-Fu
This one can possibly be closed or moved from the milestone. Waiting
for a comment from Kevin.
387604 print plug-in needs more work
We have come a good deal further here and I think that the remaining
issue is actually a GTK+ bug.
417166 Default ratio for crop tool is 1:1 instead of t manage to make the release candidate this weekend, then 2.4
will probably have to wait a little longer. I will be completely
off-line for three weeks starting from the 18th of August. This will be
my honeymoon and you guys would make me the best of all wedding presents
if we could get 2.4rc1 out before I leave. And perhaps 2.4.0 released
before I return...
