TinyScheme and GIMP
TinyScheme and GIMP Ted Gould 06 Aug 18:26
Ted Gould
2007-08-06 18:26:30 UTC (over 17 years ago)
TinyScheme and GIMP
On the Inkscape project we received a patch from the folks at Glimmer labs which adds Scheme functionality. It uses the TinyScheme interpreter which looks like it's also being used by GIMP. From what I can tell, it seems that GIMP is including TinyScheme in the source tree. Is that your long term plan? Do you expect TinyScheme to be an external library at some point? If we were using it in Inkscape also, would that change the answer? Is your TinyScheme patched for UTF-8?
Thanks, Ted
------------------------------------------------------------------------- This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/
