4 annoying things in Gimp
4 annoying things in Gimp damianzalewski 04 Aug 22:21
  4 annoying things in Gimp David Gowers 05 Aug 01:13
damianzalewski
2007-08-04 22:21:05 UTC (over 17 years ago)
1. When designing complicated project for example cd cover I often have to chain and unchain layers.
Would be nice if gimp would have option - unchain all.
2. I can't make gradients bigger the current image area. Couldn't it work like other tools.
3. Every time I want to move layer using move tool I have to click on this layer first to be able to use arrows keys on keyboard
4. I have to click on the top of image window to go to fulscreen mode (pressing TAB)
David Gowers
2007-08-05 01:13:07 UTC (over 17 years ago)
Maybe, but you can already do this in two clicks
1. shift-click on the layer chain to make a layer the only one chained 2. click on the layer chain to unchain that one too.
Works for me. Are you running GIMP on the dreaded Windows OS? ;)
At all, or on that layer? if at all, then see below about your WM. otherwise, you probably don't have that layer selected (== the active layer). If you can think of a way to improve this behaviour, then please say so.
That sounds like it's related to your window manager not giving the image window focus.
Personally I find it best to set the focus to follow the mouse, then i needn't do any clicking.
