plug_in_flush mysterious warning
plug_in_flush mysterious warning Aurimas Juška 13 Jul 13:50
  plug_in_flush mysterious warning Sven Neumann 16 Jul 17:16
   plug_in_flush mysterious warning Aurimas Juška 19 Jul 11:33
    plug_in_flush mysterious warning Aurimas Juška 20 Jul 11:29
     plug_in_flush mysterious warning Sven Neumann 20 Jul 13:03
Aurimas Juška
2007-07-13 13:50:12 UTC (over 18 years ago)
While testing my plug-in I noticed, that after quiting the plug-in The Gimp *usually* (but sometimes not, not depending on what you do) prints something like that: plug_in_flush(): broken pipe. It seems The Gimp wants to communicate with the plug-in after it's process has terminated. I added g_usleep () right before quiting in order to give The Gimp some time to finish some work. The warning doesn't appear any more.
Is it a bug or something?
Test case can be http://registry.gimp.org/plugin?id=8799 .
2007-07-16 17:16:23 UTC (over 18 years ago)
Do other plug-ins show the same behavior for you? This sounds like a bug in your plug-in. Is there perhaps an idle handler or a timeout still running?
That's quite a lot of code for a test case which makes it hard to say whether it's a problem in libgimp or in your code.
Aurimas Juška
2007-07-19 11:33:40 UTC (over 18 years ago)
Yes, it's proly a bug in my plug-in, but not an easy to find, though. Timeout handler was running, but it shouldn't be calling anything gimp_*. I made it to quit after processing, but nothing has changed. Debugging has showed, that The Gimp receives G_IO_HUP (broken pipe). After that wants to kill plug-in, on the way sending it a quit message through the same broken pipe (that's where the warning comes from). What could cause a pipe to broken if plug-in doesn't crash?
It's hard to expect that someone could find time for that. But if someone decides to check, this would envolve commenting g_usleep() in src/webx_main.c to reproduce.
Aurimas Juška
2007-07-20 11:29:54 UTC (over 18 years ago)
I used to add GimpProgressbar in order to stop showing progress of temporary processing in image window (it was just created to capture progress events but not shown). Removing it seems to make the problem disappear. Is there any other way I could hide those temporary messages?
2007-07-20 13:03:41 UTC (over 18 years ago)
If you can make a simple test case we can surely fix the problem, whether it is in the test case or in libgimp.
