Doing an action for each color in an indexed color-palette
| Doing an action for each color in an indexed color-palette | Roberto Uhlig | 27 Jun 12:23 |
| Doing an action for each color in an indexed color-palette | David Gowers | 27 Jun 12:35 |
| Doing an action for each color in an indexed color-palette | saulgoode@flashingtwelve.brickfilms.com | 27 Jun 17:20 |
| Doing an action for each color i n an indexed color-palette | Roberto Uhlig | 27 Jun 20:40 |
| Doing an action for each color in an indexed color-palette | saulgoode@flashingtwelve.brickfilms.com | 28 Jun 08:04 |
| Doing an action for each color i n an indexed color-palette | Roberto Uhlig | 05 Jul 16:22 |
| Doing an action for each color in an indexed color-palette | David Gowers | 05 Jul 17:17 |
| Doing an action for each color in an indexed color-palette | Kevin Cozens | 06 Jul 01:52 |
has/knows anyone a script/plugin (an idea) to go color by color through an indexed color-palette and doing an action for each color?
I?d like to create from a picture with an optimized color-palette with ca. 5-10 (may be 1-256) colors new layers or new pictures for each color in palette.
Layer(s) or pictures must have the same extensions like the original picture.
The new picture must be a black and white (1-bit) palette binary tiff for using in geo information systems as visible and invisible.
Greetings
Roberto
_______________________
On 6/27/07, Roberto Uhlig wrote:
has/knows anyone a script/plugin (an idea) to go color by color through an indexed color-palette and doing an action for each color? I d like to create from a picture with an optimized color-palette with ca. 5-10 (may be 1-256) colors new layers or new pictures for each color in palette. Layer(s) or pictures must have the same extensions like the original picture. The new picture must be a black and white (1-bit) palette binary tiff for using in geo information systems as visible and invisible.
I do have an idea:
1. set the image's colormap to a grayscale gradient, where the
intensity matches the index (eg. at index 0, #000000, at index 9,
#090909..)
2. copy that
for each indice in the palette:
3. paste it as a new greyscale image
4. use the threshold function with (indice, indice) as it's range parameters
5. indexize to monochrome
6. save that image
7. delete the image from memory.
loop...
That can be completely automated by scripting
Quoting Roberto Uhlig :
has/knows anyone a script/plugin (an idea) to go color by color through an indexed color-palette and doing an action for each color? I'd like to create from a picture with an optimized color-palette with ca. 5-10 (may be 1-256) colors new layers or new pictures for each color in palette.
I have written a script
(http://flashingtwelve.brickfilms.com/GIMP/Scripts/Temp/save-as-map-masks.scm)
which attempts to address your problem. I do not know how to save
1-bit TIFFs and so my script saves the files as RGB-mode
black-and-white PNGs (I know Indexed would be smaller, but I was lazy).
From the comments in the script:
;; Saves a PNG file for each color of an Indexed image where that
;; color is replaced by white and the rest of the image is black.
;; The PNG's filename is derived from the name of the bottom
;; layer of the original Indexed image. The RGB colors are
;; appended to this name, separated by hyphens.
;; An example of an output filename would be
;; "Background-10-242-79.png".
;; The files (one for each indexed color) are saved in the same directory as
;; the original image (or to the GIMP invocation directory if a
;; new image).
thanks at first!
I'l test your script if there ist some time.
My handy way was:
1. create optimized palette
2. select by color
3. "flying layer" to new layer
4. extend layer to image extensions (important!!!)
5. rename the new layer to color or gis thema (eg. wather, street ...)
again for each color
6. save as xcf for keeping the layers
7. delete all uninteressting layers
8. create b&w palette 1-bit (may be before step 6 but layers must/should be named right)
9. save as tiff (may be with lzw-compression or not)
!!! binary tiff save had a bug in gimp 2.2 .. but works fine with my 2.3.14 !!!
reload 6. again for each layer
I'm not so good in programming and I do not know if my hady way could become a script an whitch would be better.
-----Ursprüngliche Nachricht----- Von: saulgoode@flashingtwelve.brickfilms.com Gesendet: 27.06.07 17:20:44
An: gimp-developer@lists.XCF.Berkeley.EDU Betreff: Re: [Gimp-developer] Doing an action for each color in an indexed color-palette
Layer(s) or pictures must have the same extensions like the original picture. The new picture must be a black and white (1-bit) palette binary tiff for using in geo information systems as visible and invisible.I have written a script
(http://flashingtwelve.brickfilms.com/GIMP/Scripts/Temp/save-as-map-masks.scm) which attempts to address your problem. I do not know how to save 1-bit TIFFs and so my script saves the files as RGB-mode black-and-white PNGs (I know Indexed would be smaller, but I was lazy).From the comments in the script:
;; Saves a PNG file for each color of an Indexed image where that ;; color is replaced by white and the rest of the image is black. ;; The PNG's filename is derived from the name of the bottom ;; layer of the original Indexed image. The RGB colors are ;; appended to this name, separated by hyphens. ;; An example of an output filename would be ;; "Background-10-242-79.png".
;; The files (one for each indexed color) are saved in the same directory as ;; the original image (or to the GIMP invocation directory if a ;; new image).
I have updated the script
(http://flashingtwelve.brickfilms.com/GIMP/Scripts/Temp/save-as-tiff-masks.scm). It now saves as a LZW-compressed
TIFF.
;; Saves a 1-bpp TIFF file for each color of an Indexed image where that
;; The TIFF's filename is derived from the name of the bottom
;; layer of the original Indexed image. The RGB color values are
;; "Background-10-242-79.tif".
;; The files (one for each color) are saved in same directory as
;; new image.
Hello and best thanks first,
but it doesn't work correct on my xp-pc with gimp GIMP 2.3.10.
After private consultation with saul some testing and some changes for windows (backslash \) now it works fine.
Essential change is, that saul's
;; (set! blue (fmod (aref color-map (+ 2 index)) 256))
doesn't work.
aref brings sometimes negative eg. -51 values. In that case you have to ad 256 to become the realy color-value for blue.
So I implementet
(set! blue (aref color-map (+ 2 index)))
(if (< blue 0) (set! blue (+ blue 256)))
and it does his job.
I've tested it only under WINXP with Gimp 2.3.10 and also with 2.2.11.
Because of a bug in save-tiff-plugin in gimp 2.3.x (I din't know which was the fix) it isn't possible to save black-white (1bit) indexed with older gimp's. In my 2.3.10 it works fine.
Where can I find Informations about internals of the color-map int8array data storage, because I found that negative integer values?
Greetings Roberto
-----Ursprüngliche Nachricht----- Von: saulgoode@flashingtwelve.brickfilms.com Gesendet: 28.06.07 08:04:46
(http://flashingtwelve.brickfilms.com/GIMP/Scripts/Temp/save-as-tiff-masks.scm). It now saves as a LZW-compressed TIFF.;; Saves a 1-bpp TIFF file for each color of an Indexed image where that ;; color is replaced by white and the rest of the image is black. ;; The TIFF's filename is derived from the name of the bottom ;; layer of the original Indexed image. The RGB color values are ;; appended to this name, separated by hyphens. ;; An example of an output filename would be ;; "Background-10-242-79.tif".
;; The files (one for each color) are saved in same directory as ;; the original image (or to the GIMP invocation directory if a ;; new image.
but it doesn't work correct on my xp-pc with gimp GIMP 2.3.10. After private consultation with saul some testing and some changes for windows (backslash \) now it works fine. Essential change is, that saul's
;; (set! blue (fmod (aref color-map (+ 2 index)) 256)) doesn't work.
aref brings sometimes negative eg. -51 values. In that case you have to ad 256 to become the realy color-value for blue. So I implementet
(set! blue (aref color-map (+ 2 index))) (if (< blue 0) (set! blue (+ blue 256))) and it does his job.
I've tested it only under WINXP with Gimp 2.3.10 and also with 2.2.11.Because of a bug in save-tiff-plugin in gimp 2.3.x (I din't know which was the fix) it isn't possible to save black-white (1bit) indexed with older gimp's. In my 2.3.10 it works fine.
I don't know where you can find that info; but I know myself -- Each image's colormap is made up of sets of 3 bytes (R,G,B); these values are unsigned. Since you have found you had to add 256 to the values in that case, it seems to me that script-fu must be wrongly treating the colormap values as signed values, and this is a bug.
[snip]
aref brings sometimes negative eg. -51 values. In that case you have to ad 256 to become the realy color-value for blue. So I implementet (set! blue (aref color-map (+ 2 index))) (if (< blue 0) (set! blue (+ blue 256))) and it does his job. I've tested it only under WINXP with Gimp 2.3.10 and also with 2.2.11.
INT8 and INT8ARRAY used to be signed values but these types were changed to unsigned a few versions back in the development version of GIMP. They are still signed entities in the 2.2 series of GIMP so storing values > 127 will read back as negatives.
Aref doesn't return negative values in the current development version of GIMP (built from SVN).
