./configure doesn't recognize libexif
./configure doesn't recognize libexif Richard Hirner 21 Jun 13:21
  ./configure doesn't recognize libexif Mukund Sivaraman 21 Jun 13:24
   ./configure doesn't recognize libexif Richard Hirner 21 Jun 13:30
   ./configure doesn't recognize libexif Michael Schumacher 21 Jun 14:31
    ./configure doesn't recognize libexif Sven Neumann 21 Jun 21:10
Richard Hirner
2007-06-21 13:21:47 UTC (almost 18 years ago)
I tried to compile the latest GIMP version from the SVN trunk. My problem: the ./configure script (called from autogen.sh) doesn't recognize libexif although the libexif-dev and libexif-gtk-dev packages are installed and the headers and libs are indeed present:
user@ubuntu:~/tmp$ ls /usr/include/libexif exif-byte-order.h exif-entry.h exif-log.h exif-utils.h exif-content.h exif-format.h exif-mem.h _stdint.h exif-data.h exif-ifd.h exif-mnote-data.h exif-data-type.h exif-loader.h exif-tag.h user@ubuntu:~/tmp$ ls /usr/include/libexif-gtk/ gtk-exif-browser.h gtk-exif-entry.h gtk-exif-content-list.h gtk-exif-entry-number.h gtk-exif-entry-ascii.h gtk-exif-entry-option.h gtk-exif-entry-copyright.h gtk-exif-entry-rational.h gtk-exif-entry-date.h gtk-exif-entry-resolution.h gtk-exif-entry-flash.h gtk-exif-entry-user-comment.h gtk-exif-entry-generic.h gtk-exif-entry-version.h
... ./configure output ... Plug-In Features:
EXIF support: no (libexif not found) ...
Mukund Sivaraman
2007-06-21 13:24:57 UTC (almost 18 years ago)
Hi Richard
You need at least libexif 0.6.15.
Kind regards,
Mukund
Richard Hirner
2007-06-21 13:30:14 UTC (almost 18 years ago)
Ok thanks, that solves the problem. I have libexif 0.6.13 which is shipped with Ubuntu 7.04.
2007-06-21 14:31:14 UTC (almost 18 years ago)
Von: Mukund Sivaraman
The summary should indicate this - use "too old" rather than "not found".
2007-06-21 21:10:21 UTC (almost 18 years ago)
It could do that. But there is already informative output when the test for libexif is run. It would be quite some effort to change all tests in configure to put that information into the summary. Quite error-prone and IMO not worth the effort. People compiling GIMP should examine the configure output.
