overwrite problem
overwrite problem Luis A. Florit 15 Jun 07:41
  overwrite problem Sven Neumann 16 Jun 16:09
   overwrite problem Luis A. Florit 16 Jun 16:44
Luis A. Florit
2007-06-15 07:41:29 UTC (almost 18 years ago)
overwrite problem
I am having an 'overwrite file' problem in 2.3.18. When trying to save a file that already exists, ask as usual if you want to overwrite. If you say YES, it does NOT overwrite, and writes a Untilted.xcf file instead.
Thanks,
Luis.
2007-06-16 16:09:09 UTC (almost 18 years ago)
overwrite problem
Are you absolutely sure? What does it display in the image status bar?
I cannot reproduce this, tried with GTK+ 2.10.13 and GTK+ 2.11.3.
Luis A. Florit
2007-06-16 16:44:58 UTC (almost 18 years ago)
overwrite problem
* El 16/06/07 a las 16:09, Sven Neumann chamullaba:
I got this 3 different days, and several times...
Strange...
Because now I cannot reproduce this either! And I made no systems updates.
Well, sorry for this. If I get the same behavior again, will report back.
Thanks,
Luis.
