GEGL is no longer vapor. (was: improving image scale: reduction)
GEGL is no longer vapor. (was: improving image scale: reduction) Øyvind Kolås 10 Jun 23:13
  GEGL is no longer vapor. (was: improving image scale: reduction) g4@catking.net 11 Jun 12:22
  GEGL is no longer vapor. (was: improving image scale: reduction) gg@catking.net 15 Jun 21:03
   GEGL is no longer vapor. (was: improving image scale: reduction) David Gowers 16 Jun 02:33
Øyvind Kolås
2007-06-10 23:13:03 UTC (almost 18 years ago)
On 6/10/07, g4@catking.net wrote:
On Sun, 10 Jun 2007 13:12:02 +0200, Sven Neumann wrote:
For GIMP 2.6, we will need high-quality and optimised scaling algorithms implemented as GEGL operators. Perhaps it would be a good idea to write such operators now so that we can start to use them when we port the core to GEGL.
Doubtful. I can find a bit of time to tweek in the existing code but 2.6 seems a very long way off just now and I really dont have the time to get deeply into geggling.
GEGL supposedly has quite readable code that is running and works, modifying that code base to deal with this properly will most probably been seen as more lasting contributions than changing code that eventually only will live on machines running legacy 2.4 series GIMP due either to low performance hardware or depending on legacy behavior like having an indexed mode.
A bit nearer the time maybe.
The time is now, and GIMP will soon enough start needing more and more adjustments/specialized operations to be implemented. More people looking at the code, and complain when things are difficult to understand, namings of APIs could be changed; will help getting the GEGL code base and APIs into sufficiently good shape for the 2.5 development cycle of GIMP.
/Øyvind K.
g4@catking.net
2007-06-11 12:22:52 UTC (almost 18 years ago)
algorithms
write
/Øyvind K.
OK, maybe this is going to happen sooner than I thought. With 2.4 still not released after nearly 2 yrs , talking about 2.6 seems like planning for a replacement for the Kyoto Protocol ;)
I know my own little corner of the gimp code but getting familiar with a new API is an order of magnitude more time.
I'll start to look into GEGL when I have time but that's not now.
thx gg/
gg@catking.net
2007-06-15 21:03:31 UTC (almost 18 years ago)
hmm, just reread this. Does that comment indicate that GEGL is a lot more resource hungry than gimp? I'd wondered if that might the case when I initially looked at the way it was structured.
thx.
David Gowers
2007-06-16 02:33:25 UTC (almost 18 years ago)
I thought it was fairly clear that Øyvind mainly meant CPU power ('low performance' -- RAM would correspond to 'low capacity'). Currently, my impression from using GEGL is: a) it wants more memory for an equivalent layer-arrangement b) it wants to use less memory at a time
relative to GIMP. a) because of the way that layers are composited of multiple GEGL ops, and b) because of caching -- if a graph node is not dirty, then it doesn't need to be recalculated from it's child nodes*. So it uses more memory during calculation, and less memory during editing (depending on the dependencies of the node you're editing).
*the caching system is still under development, as far as I can tell; final caching behaviour is not determined except in that it will be something like i described.
Per the above, it seems to me clear that GEGL will be more usable on systems with low memory and lots of swap space VS the GIMP's current infrastructure, with efficiency while editing varying more (initially with all ops written in C, individual op speed will be less but caching will tend to speed up editing past GIMP speeds.)
