bash command inside script
3 of 4 messages available
bash command inside script Luis A. Florit 04 Jun 03:47
200706041649.01442.gwidion@... 07 Oct 20:25
  bash command inside script Luis A. Florit 05 Jun 02:41
  bash command inside script Luis A. Florit 05 Jun 02:50
Luis A. Florit
2007-06-04 03:47:43 UTC (almost 18 years ago)
Is there a way to read the output of a bash command inside a script-fu? I want to make a script-fu that uses the ExifTool program output.
Thanks!
Luis.
Luis A. Florit
2007-06-05 02:41:56 UTC (almost 18 years ago)
* El 04/06/07 a las 16:49, Joao S. O. Bueno Calligaris chamullaba:
Thanks!
Luis.
two words:
go python
Seriously. Script-fu has the advantage that it can have a small itnerpreter which can therefore live inside GIMP's source tree. And that is it. Of course, it fits whoever likes solving puzzles on how to perform simple tasks such as parsing a string letter by letter, or getting the output of a file.
Python is a full featured language, which greatest advantage is to allow one to concentrate on his problem instead of the language.
Just check some of the python-fu examples that come with GIMP itself.
Use the "os" module to be able to spawn sub-proccess and read the output, like in:]
import os
files = os.popen ("ls devel/gimp").readlines() for file in files:
... print file.upper()
ACINCLUDE.M4
ACLOCAL.M4
APP
AUTHORS (in time: the >>> and ... are prompts put ther by the interactive interpreter, not part of the language itself)
js ->
Luis A. Florit
2007-06-05 02:50:55 UTC (almost 18 years ago)
Sorry for the empty email I've just sent. My mistake. Now, about my question:
This is to answer Kevin:
Save the output from the ExifTool to a file and have the Script-Fu script read the file with the saved output.
I think this is not practical for what I need (that of course you didn't need to know).
My script has a field in the GUI to enter the ExifTool data. I think that copy-pasting the data to this field is easier than running Exiftool, saving its output to a file for each image.
Now, the answer to Joao:
two words:
go python
import os
ACINCLUDE.M4
ACLOCAL.M4
APP
I agree. In fact, I always found the script-fu language (a variant of lisp, right?) simply horrible. However, my script-fu is 100% functional, and I think that it doesn't worth it the effort to translate the full script to python just because of this. But I will take your advice for the next time, and my next plugin will be in python from the beginning.
Thank you both!!!
L.
