Quick mask malfunctioning on gray scale pictures
Quick mask malfunctioning on grayscale pictures Vladimir Savic 29 May 14:52
  Quick mask malfunctioning on grayscale pictures Sven Neumann 29 May 20:04
   Quick mask malfunctioning on grayscale pictures Sven Neumann 29 May 20:08
    Quick mask malfunctioning on gray scale pictures Vladimir Savic 29 May 23:30
     Quick mask malfunctioning on grayscale pictures Sven Neumann 29 May 21:37
      Quick mask malfunctioning on gray scale pictures Vladimir Savic 30 May 01:41
Vladimir Savic
2007-05-29 14:52:34 UTC (almost 18 years ago)
I think this is a bug. If not, then it's a serious application design issue.
Shift+Q on grayscale pictures ignores color setup for quick mask. Default red appears as mid intensity gray which makes this great functionality useless on most occasions (for mottled pictures almost always).
Any thought or should I go for filling a bug report?!
Regards, Vladimir
2007-05-29 20:04:10 UTC (almost 18 years ago)
Of course you could file a bug report but we would appreciate if you could also try to fix the issue and provide a patch. I very much doubt that someone else will find the time to fix it.
2007-05-29 20:08:28 UTC (almost 18 years ago)
thinking about it, I don't think it can be fixed. Quick Mask is just a UI shortcut for using a channel. And a grayscale image can only have grayscale channels. So if you filed a bug report for this, we would probably have to close it as WONTFIX.
2007-05-29 21:37:55 UTC (almost 18 years ago)
On Tue, 2007-05-29 at 21:30 +0000, Vladimir Savic wrote:
Workaround is really easy, anyway: Find average pixel value for particular picture and give quick mask some high contrast gray value. Simple...
Except that, as outlined already, quickmask is just a user interface to channels. And as long as we don't have spot color channels, it doesn't make sense to allow non-grayscale channels in a grayscale image.
The simple workaround is really to convert the image to RGB mode.
Vladimir Savic
2007-05-29 23:30:47 UTC (almost 18 years ago)
Unfortunately, I thought it's not simple thing to do. :(
Hm... Wouldn't it be much more reasonable to give it a resolution like 2.6, 3.0 or even low-resolution-version-16.0-maybe?! There would be, at least, info that feature is being requested once and that it couldn't be implemented because of technical reasons, so that users do not request it again. Just a bad attitude for totally reasonable feature request, IMHO.
Isn't WONTFIX reserved for inappropriate wishes?!
Regards, Vladimir
Vladimir Savic
2007-05-30 01:41:20 UTC (almost 18 years ago)
True! :) Funny but true... Seems like I always see harder way to achieve something... :)
Thanks,
Vladimir
