Plug-in-convmatrix and INT32ARRAY
Plug-in-convmatrix and INT32ARRAY Dommett, David W CTR USAF AFRL/HEC 21 May 13:14
  Plug-in-convmatrix and INT32ARRAY saulgoode@flashingtwelve.brickfilms.com 21 May 17:01
2007-05-21 13:14:44 UTC (about 18 years ago)
Is it possible to call plug-in-convmatrix from a Scheme script? The 10th parameter needs to be an INT32ARRAY however I don't know how to create one of these in Scheme. If I try something like a float array I just get an error message stating that it is the wrong type. "cons-array" only accepts string, byte, double and lisp as types.
2007-05-21 17:01:52 UTC (about 18 years ago)
Quoting "Dommett, David W CTR USAF AFRL/HEC" :
I don't have access to the GIMP right now, but looking at some of my notes it appears that you would create an INT32ARRAY with
(define a (cons-array num-elements 'long))
