Panorama Previewer plug-in
Panorama Previewer plug-in Leon Moctezuma 08 Apr 18:40
  Panorama Previewer plug-in Michael Schumacher 13 Apr 21:57
   Panorama Previewer plug-in Leon Moctezuma 13 Apr 22:30
    Panorama Previewer plug-in Sven Neumann 16 Apr 08:42
Leon Moctezuma
2007-04-08 18:40:30 UTC (about 18 years ago)
Hi I'm an student applying for Google Summer of Code, my mentor organization is hugin/panotools, if I'm accepted I will be working in FreePV a panoramic
viewer, which only has at this moment a stand alone and mozilla plug-in implementation (OpenGL/C++), we are looking to make of FreePV something unique and we wonder if it's posible to write a panorama previewer using libgimp.
2007-04-13 21:57:14 UTC (about 18 years ago)
Hi Leon,
I did notice (at http://code.google.com/soc/pano/about.html) that you got accepted for GSoC - congrats and best wishes for success.
libgimp is supposed to be used by GIMP plugins - you can't use it in a different program to get GIMP's capabilities added to this.
But maybe you didn't want to do this and want to create a GIMP plug-in or make it possible for FreePV to be run as a plug-in, like for example it is possible with XSane?
Regards, Michael
Leon Moctezuma
2007-04-13 22:30:12 UTC (about 18 years ago)
Thanks Michael, I'm very excited with this project and I'll do anything to make it success
Yes, I want to make it run as a plug-in, the actual implementation of freepv uses OpenGL and if I'm not wrong I can use gtk+ to render with OpenGL..
How can I make it run as a plug-in...? I want to use the image in the workspace
of gimp to build the panorama in OpenGL to preview the final result Do you have any article or reference? where I can read about this?
Regards Leon
2007-04-16 08:42:32 UTC (about 18 years ago)
developer.gimp.org has pointers to tutorials and to the API reference manual. The gimp source code contains more than hundred plug-ins that can be used as code examples.
Since you want to use OpenGL, you will also want to look at gtkglext (http://www.k-3d.org/gtkglext/Main_Page)
