internal representation of a selection
7 of 7 messages available
internal representation of a selection Helmut Jarausch 30 Mar 18:10
  internal representation of a selection Joao S. O. Bueno Calligaris 30 Mar 19:53
  internal representation of a selection Kevin Cozens 30 Mar 20:24
   internal representation of a selection Helmut Jarausch 31 Mar 13:10
    internal representation of a selection Hal V. Engel 31 Mar 18:44
    internal representation of a selection peter sikking 31 Mar 18:55
internal representation of a selection William Skaggs 01 Apr 16:48
Helmut Jarausch
2007-03-30 18:10:56 UTC (almost 18 years ago)
can somebody, please, point me to some information on how a selection is represented (internally) within Gimp and how one can access this. Is it represented by a matrix of bits? If the selection has many holes it's not sufficient to have a lower and upper bound for each pixel row. I need the selection exactly for my attempt at a new healing tool.
Many thanks for a pointer,
Helmut Jarausch.
2007-03-30 19:53:53 UTC (almost 18 years ago)
Hi Helmut -
the selection is a matrix of bits, yes - a "drawable" object, with one byte per pixel, meaning the "strenght" of the selection at that point.
the call gimp_image_get_selectin available for plug-ins can return you the selection as a drawable object.
Through the UI you can simply enable the quickmask (click on the little square to the left of the hor. scroll bar on an image window), to transfer the selection to an editable image channel.
js ->
Helmut Jarausch.
Kevin Cozens
2007-03-30 20:24:24 UTC (almost 18 years ago)
It is good to have another person around who is interested in working on a healing tool for GIMP.
Before you start, are you aware that a healing tool was added to the current development version of GIMP? It was created by Kevin Sookocheff as part of the 2006 Google Summer of Code program.
The healing tool has a couple of bugs filed against it. You may find your time would be better spent fixing and polishing the existing healing tool instead of starting a new one. On the other hand, if you have an idea for a different or better approach to a healing tool that what is in the current development release, I'm sure the GIMP developers would be interested to hear about your ideas for a new version of a healing tool.
Helmut Jarausch
2007-03-31 13:10:19 UTC (almost 18 years ago)
We had some discussions here 5 weeks, ago. I had a look at the current implementation (in the development version). There I found the reference to a paper by T. Georgiev (from Adobe). The current implementation fails in some fundamental aspects. (Only) to explain the problems I'll make the simplifying assumption that the region to be healed ("destination area") is the interior of a circle, which I'll call the boundary below. Georgiev's algorithm proceeds in 2 steps:
step 1 is identical to the clone tool, i.e. some source area of identical shape to the destination area is copied into the interior of the destination area (interior of the circle)
setp 2 Now, at each pixel at the boundary we have 2 values: the previous value of the destination area and the new value of the source area which has not yet been copied. Georgiev tries to fit the area in the interior of the circle (which has just been copied from the source area) to the (old) outside of the circle. To do that he computes the quotients of the old values at the boundary divided by the new values there (for each color separately). Then he suggests to "pull" these factors smoothly into the interior of the circle - see below. Once he has got all these factors, he multiplies all values in the interior by the corresponding factors. Thus, we get a perfect fit on the boundary and hopefully a pleasing one in the interior. Note that it is absolutely essential that the (old) boundary doesn't contain a single "defective" pixel since this defective value would have been "pulled" into the interior of the circle.
To "pull" the factors at the boundary smoothly into the interior he suggests to solve a so-called Poisson equation (= Laplace equation). Unfortunately the solution of this equation is very expensive unless one uses the right (a bit complicated) algorithm called multi-grid. The current implementation use a very simple iterative algorithm (called Gauss-Seidel relaxation) which is not suitable for more than say a few hundreds of pixels. Even then it would take a significant time to solve the equation. The current implementation just puts a fixed upper bound on the number of iterations.
So, it simply doesn't solve this equation in all but trivial cases. For thousand and more pixels (which is still a tiny part of a 10 Megapixel image) this algorithm could take hours or more to complete.
My current plan encompasses a few steps outlined below. Perhaps I'll add a quick mode which would be similar to the clone tool lateron.
- In step 1 the user creates a selection which selects the area to be healed paying attention to the boundary of that selection to contain good (i.e. typical) values of the image. The user can use any of Gimp's selection tools including the quick mask for that purpose. Once finished (e.g. signaled by pressing a button) the heal tool will remember that selection.
- In step 2 one invokes the Move Tool to move the selection into a suitable "source area". I'll try to copy the source to the destination on the fly so the user can see the effect (of the clone tool) immediately. Satisfied with the source region the user proceeds to step 3 - again by pressing a button (somewhere)
- In step 3 the healing tool starts working. For that it applies a given number of iterations of the so-called multi-grid algorithm. The nice thing about this algorithm is its speed independent(!) of the number of unknowns (= unknown factors). Probably less than 5 iterations will do even for millions of unknowns. I think I'll let the user select the number of iterations calling it the "strength" (or a similar word) of the healing tool. Strength 0 will give results identical to the clone tool. Strength 5 (?) will give the full effect of the healing tool as described by Georgiev. Let's see if an intermediate strength gives interesting (noticeably different) results.
For the "quick mode" the user starts by specifying a point somewhere within his source area. Then - exactly like the clone tool - he paints the destination area. BUT, once he/she releases the mouse button or lifts the pen, the healing algorithm would be started. It will give bad results if the boundary of the destination area still contains "defective" pixels.
I am looking forward to your comments, Helmut.
Hal V. Engel
2007-03-31 18:44:57 UTC (almost 18 years ago)
This is exactly how the heal tool works in Photoshop. It is actually fairly common to have to go back over areas in the healing region where the defective pixels were not completely healed when working with larger defects such as cracks in old photos. I don't see this as an issue.
Hal
peter sikking
2007-03-31 18:55:39 UTC (almost 18 years ago)
I have no idea who we will help with a non-quick mode.
I see that this tool can be integrated in the clone tool, for an interaction architect that is a 'done deal.'
I can live with a "clone, and then see the paint dry" effect, as it gets the job done.
It will give bad
So if you do not heal all defective pixels, you will not have complete healing? sounds fair enough to me.
I would like to ask you if you can help us with two things:
1) is it possible for the user to incrementally include the defective pixels in the healing (heal these additional pixels with the brush) and in a relatively short time, the healing would be 'perfect.'
2) can you in very clever way pretend the defective boundary pixels should also be healed in order to do a good job on actually to be healed pixels?
Thanks,
--ps
principal user interaction architect man + machine interface works
William Skaggs
2007-04-01 16:48:17 UTC (almost 18 years ago)
Date: Sat, 31 Mar 2007 13:10:19 +0200 (CEST)
Helmut,
A couple of thoughts.
First, there would be a big advantage in starting from the existing healing tool code instead of creating a new one completely from scratch -- the advantage is that a lot of developer time has gone into the user-interaction aspects of the existing code, and people would perhaps not be so patient if they had to repeat with you all of the advising that went on with sookocheff.
Second, your approach requires a multi-scale solver. Do you propose to write one from scratch, or to use an existing one?
Third, an approach that makes use of the selection and source-center, without requiring any painting, does not need to be a tool at all -- it can, and probably should, be implemented as a plug-in. You would probably find it easier to develop that way, since the libraries used by plug-ins are far better documented than most of the functions used in the core.
-- Bill
