my plugin not works now!!
my plugin not works now!! coolhand 27 Mar 12:08
  my plugin not works now!! Sven Neumann 28 Mar 13:56
   my plugin not works now!! coolhand 29 Mar 10:17
    my plugin not works now!! Michael Natterer 29 Mar 10:56
     my plugin not works now!! coolhand 29 Mar 13:38
coolhand
2007-03-27 12:08:56 UTC (almost 18 years ago)
I'm developing a new plugin for gimp that works in the 2.2 series, but not in 2.3.10. It shows the menu entry in gray, but there aren't any messages in the console about.
In the other hand, i have other plugin that works fine. In this case, is a load image plugin, but shows in console: "GIMP: save handler "plugin-lct-load" does not take the standard save handler args", when i use the standard load args.
thanks.
2007-03-28 13:56:02 UTC (almost 18 years ago)
You would have to show us the code of your plug-in if you want us to help you.
coolhand
2007-03-29 10:17:56 UTC (almost 18 years ago)
Ok.
http://www.nabble.com/file/7507/gimp_gdal_plugin.c gimp_gdal_plugin.c
This is a plugin to load image files from the gdal library (Geospatial Data Abstraction Library). As this library loads some of common file types such as jpeg, tiff, etc, i thinked to make an alternative dialog to load from; therefore this is a general plugin, and not a load plugin.
Also, when i opened images, the plugin still continue working, but when i close one of these images, the menu item gones gray and i can't use any more.
This other one is a load file plugin:
http://www.nabble.com/file/7508/gimp_lct_plugin.c gimp_lct_plugin.c
it works fine at first time. To work it needs to be reinstalled, and then it only works once again. ¿why? for me is a mistery.
Michael Natterer
2007-03-29 10:56:39 UTC (almost 18 years ago)
Ok.
the problem is that you specify "GREY" as image type for your open procedures. That means you can only use these procedures if your currently active image is greyscale. That's probably not what you want, just pass an empty string there ("").
And unrelated:
For the first plug-in, there is no reason any more to have image and drawable parameters just because a procedure registers in , just get rid of these useless parameters too and your plug-in will continue to work just as before.
ciao, --mitch
coolhand
2007-03-29 13:38:50 UTC (almost 18 years ago)
Ok, all works now!.
