setting sliders/spinbutton values
setting sliders/spinbutton values Luis A. Florit 26 Mar 22:54
  setting sliders/spinbutton values Sven Neumann 26 Mar 23:08
Luis A. Florit
2007-03-26 22:54:06 UTC (over 18 years ago)
Pals,
I made a plugin thas has some scales created by 'gimp_scale_entry_new'. Is there a way of changing the value of the sliders and spin buttons AFTER the dialog window is created according to the output of some fuction, say, by pressing a button in the dialog that calls this function?
Thanks!
Luis.
2007-03-26 23:08:08 UTC (over 18 years ago)
The very same way you set the values before the dialog window is created. You call gtk_adjustment_set_value() on the GtkAdjustment object that is returned from gimp_scale_entry_new().
