Gimp natively on mac OS X
| Gimp natively on mac OS X | M. Gagnon | 25 Mar 00:52 |
| Gimp natively on mac OS X | Axel Wernicke | 25 Mar 01:11 |
| Gimp natively on mac OS X | M. Gagnon | 25 Mar 03:37 |
| Gimp natively on mac OS X | Axel Wernicke | 25 Mar 09:40 |
| Gimp natively on mac OS X | M. Gagnon | 25 Mar 17:28 |
| Gimp natively on mac OS X | Axel Wernicke | 25 Mar 17:34 |
| Gimp natively on mac OS X | Michael Natterer | 26 Mar 10:37 |
| Gimp natively on mac OS X | Nathan Summers | 26 Mar 16:53 |
| Gimp natively on mac OS X | M. Gagnon | 26 Mar 17:04 |
Hi everyone,
i just thought i would report my sucess of building Gimp on mac OS X with
native GTK+ port by Imendio
(http://developer.imendio.com/projects/gtk-macosx).
Screenshot: http://img402.imageshack.us/my.php?image=gimpxct0.jpg
Right now things are working rather well. There a few visual glitches and menus and spinners sometimes don't work - but overall it is usable. Not ready to be used by users, however. and almost impossible to package and distribute until the gtk mac team work on distribution.
Overall the process was not too hard, i however had to change a makefile at one point. The one located in /app/Makefile contains a line 'munix = -Wl,-rpath '-Wl,$$ORIGIN/../lib'' - this line is incompatible with mac OS X because it uses Apple's ld, not GNU's. I just made munix empty and everything built fine. Do you think makefiles can be adapted to be cross-platform or do you support only linux?
Finally, i thought it might be a good idea to set up a wiki page where i'd write the build steps i followed so that other people don't have to do as much research and trial-and-error.
Thanks!
PS: I might be interested about doing some code development on linux as well possibly - maybe after i've spent a few months studying the code ;) I'm not very quick at getting into such big projects
__________________
Congratulations!
I'm a member of the GIMP documentation team and eager to see the gtk native project progressing! I'm working on OS X @ an MBP myself. So, how you put the description on the GIMP wiki[1]? There is already a "How to build on Windows"[2] page which might be happy to get a twin.
Greetings, lexA
[1] http://wiki.gimp.org/gimp/FrontPage?action=show&redirect=StartSeite [2] http://wiki.gimp.org/gimp/HowToCompileGimp
Am 25.03.2007 um 00:52 schrieb M. Gagnon:
Hi everyone,
(http://developer.imendio.com/projects/gtk-macosx).Screenshot: http://img402.imageshack.us/my.php?image=gimpxct0.jpg
distribute until the gtk mac team work on distribution.Overall the process was not too hard, i however had to change a makefile at
because it uses Apple's ld, not GNU's. I just made munix empty and everything built fine. Do you think makefiles can be adapted to be cross-platform or do you support only linux?Finally, i thought it might be a good idea to set up a wiki page where i'd
much research and trial-and-error.Thanks!
very quick at getting into such big projects__________________
how do you create a wiki page? can 'regular' users do, or must some moderator do it? i tried following the 'creating a wiki page' info, but it always showed up as black text
thanks
To: "M. Gagnon"
CC: GIMPDev
Subject: Re: [Gimp-developer] Gimp natively on mac OS X Date: Sun, 25 Mar 2007 01:11:55 +0100Congratulations!
Greetings, lexA
Hi everyone,
i just thought i would report my sucess of building Gimp on mac OS X with native GTK+ port by Imendio
write the build steps i followed so that other people don't have to do as much research and trial-and-error.Thanks!
Am 25.03.2007 um 03:37 schrieb M. Gagnon:
always showed up as black textthanks
The MagicWords needed som " around to be recognised. I restored your text and created the new page at http://wiki.gimp.org/gimp/ HowToCompileGimp/MacOSX .
Greetings lexA
Thanks,
i wrote a first set of instructions. It's rather long and painful, but hey it worked ^^
but just a quick question... i thought i'd try color management, but it was a bad idea because now it fails loading the profile and won't start anymore! how can i reset the color profiles used? i tried uninstalling and reinstalling it but it still tried to open the profiles
To: "M. Gagnon"
CC: gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] Gimp natively on mac OS X Date: Sun, 25 Mar 2007 09:40:27 +0200Hi,
Greetings lexA
__________________
Everything that related to GIMP preferences should be below ~/.gimp-2.x But this is rather a topic for gimp-user than for the developers list.
Greetings, lexA
Am 25.03.2007 um 17:28 schrieb M. Gagnon:
Thanks,
it worked ^^but just a quick question... i thought i'd try color management, but it was
how can i reset the color profiles used? i tried uninstalling and reinstalling it but it still tried to open the profilesFrom: Axel Wernicke
To: "M. Gagnon"
it
and created the new page at http://wiki.gimp.org/gimp/ HowToCompileGimp/MacOSX .Greetings lexA
__________________
On Sat, 2007-03-24 at 19:52 -0400, M. Gagnon wrote:
Hi everyone,
That's odd, since I have to change *nothing* in any of the source packages to get the entire toolchain plus gimp build on OS X.
I can't look into that right now but will do as soon as I have access to my apple machine again,
ciao, --mitch
Hi everyone,
(http://developer.imendio.com/projects/gtk-macosx).Overall the process was not too hard, i however had to change a makefile at one point. The one located in /app/Makefile contains a line 'munix = -Wl,-rpath '-Wl,$$ORIGIN/../lib'' - this line is incompatible with mac OS X because it uses Apple's ld, not GNU's. I just made munix empty and everything built fine. Do you think makefiles can be adapted to be cross-platform or do you support only linux?
Perhaps the difference is due to a different version of one of the autofoo tools, or a different version of XCode.
Rockwalrus
I do not have the very latest developer tools installed, so that may explain the difference. I have updated the wiki info accordignly, thanks for pointing out.
Hi everyone,
with
makefile at
OS X
Rockwalrus
__________________
