Brush Scaling
Accessing the size and rotate settings through the pdb would be great,
here is a lot of ways that I would end up using it...
I have a few scripts where I have needed to change rotation and size of
a brush... What I've ended up doing is creating a new layer, paint one
instance at x,y, and then resize it - rotate it - merge it down - It
works but it's very, very time consuming when you have a script that
does it several dozen times...
Multiple strokes on the same path or selection for sure... You could
make some nice border scripts just by using different rotate, scale, and
spacing settings with the same brush layered on top of each other...
anyway thanks again for everything so far, it is really appreciated...
(I've been using it constantly)
Joao S. O. Bueno Calligaris wrote:
On Thursday 15 March 2007 07:22, jbaker wrote:
Thanks for all the work on this one, it works great...
I was just curious if there are any plans add the ability to scale
and rotate the standard brushes with python ? I did a quick search
in the procedure browser but didn't see anything except the
functions for the generated brushes...
thanks,
no plans made - except for generated brushes (the ones you can create
and edit from within the brush dialog).
But this is an area I am thinking about. (actually, mostly the pdb for
brush stroking)
Please say a little more on what you are planning to do (the final
effect).
js
jerry
