what algorithm is used in Ctrl-K?
what algorithm is used in Ctrl-K? zhang chi 01 Mar 15:08
  what algorithm is used in Ctrl-K? saulgoode@flashingtwelve.brickfilms.com 03 Mar 01:25
   what algorithm is used in Ctrl-K? David Gowers 03 Mar 03:18
    what algorithm is used in Ctrl-K? saulgoode@flashingtwelve.brickfilms.com 03 Mar 11:05
zhang chi
2007-03-01 15:08:04 UTC (about 18 years ago)
http://www.gimptalk.com/forum/topic/My-First-Tutorial-Blending-Images-In-Gimp-106-1.html
in this tut, after feather,C-i,and C-K is used, but what algorithm is used when using Ctrl-k ?
thank you
2007-03-03 01:25:53 UTC (about 18 years ago)
Quoting zhang chi :
thank you
If the layer has an alpha channel then the value of the alpha is scaled by (1 - S) where "S" is the selection mask's value (which spans the range '0=not selected' to '1=fully selected' -- the selection is actually a value from 0 to 255).
If there is no alpha channel then the value of each of the components (RGB) is scaled by (1 - S) and added to the product of the corresponding component of the active background color and (1 - S).
For Indexed Mode images, the resulting pixel is the active BG color if S>0.5 and unchanged if S
David Gowers
2007-03-03 03:18:26 UTC (about 18 years ago)
On 3/3/07, saulgoode@flashingtwelve.brickfilms.com < saulgoode@flashingtwelve.brickfilms.com> wrote:
Quoting zhang chi :
used
when using Ctrl-k ?
thank you
For Indexed Mode Images, the resulting pixel is the active BG color if the layer has no alpha and S > 0.5, (emptiness) if S > 0.5 and the layer has an alpha channel, and unchanged if S < 0.5.
2007-03-03 11:05:58 UTC (about 18 years ago)
Quoting David Gowers :
Quoting zhang chi :
used
when using Ctrl-k ?
thank you
Oops, forgot that case.
Also, there is an error in my description:
The very last term in the sentence should be "S" -- not "(1 - S)".
