GIMP jpeg-exif issue (#377917)
GIMP jpeg-exif issue (#377917) Mukund Sivaraman 16 Feb 11:04
Mukund Sivaraman
2007-02-16 11:04:06 UTC (about 18 years ago)
Hi Bill
Please take a look at: http://bugzilla.gnome.org/show_bug.cgi?id=377917
From svn blame, I found that you had put in the ExifVersion check in comment #4 (revision 16371). Is there a strong reason to have this? We do want to support incomplete EXIF information (even if it's broken). Does libexif return exif_data even though there's *absolutely no EXIF info* in the file?
We may need to remove this check and also the check for thumbnails (in the statement preceding this if) to handle files with broken EXIF information gracefully. I'd appreciate your comments on this. How else can we check if the exif_data has any valid EXIF data, without checking for ExifVersion?
Kind regards,
Mukund
