strange localization behaviour (gimp-2.3-svn)
I just noted this strange behaviour: when I see the the Image menu->View->Display filters->Color Deficient Vision options (Protanopia, Deuteranopia, Tritanopia) with the Italian locale, _all_ but these three options are translated. Is it my svn copy fault or does it have this behaviour in other languages too?
TIA
Sorry, but I don't understand your question. What's translated and what's not? And did you already check in the it.po files that the strings have been translated at all?
Sorry for my bad english...
The problem seems around the option pulldown menu...
Of course, the it.po file is correctly translated.
Maybe I have some problems in the configure procedure?
running ./configure & make I get:
make
Making all in gui
make[3]: Entering directory `/home/marco/svn-gnome/gimp/trunk/app/gui'
if gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -I../.. -I../../app
-I../../app -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include
-I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0
-I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include
-I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/glib-2.0
-I/usr/lib/glib-2.0/include -I/usr/local/include
-DG_LOG_DOMAIN=\"Gimp-GUI\" -pthread -I/usr/include/glib-2.0
-I/usr/lib/glib-2.0/include -DGIMP_DISABLE_DEPRECATED
-DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED
-DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED
-DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -g -O2 -Wall
-Wdeclaration-after-statement -Wmissing-prototypes -Wmissing-declarations
-Winit-self -Wpointer-arith -MT gui.o -MD -MP -MF ".deps/gui.Tpo" -c -o
gui.o gui.c; \
then mv -f ".deps/gui.Tpo" ".deps/gui.Po"; else rm -f
".deps/gui.Tpo"; exit 1; fi
In file included from /usr/include/dbus-1.0/dbus/dbus-glib-lowlevel.h:28,
from gui.c:27:
/usr/include/dbus-1.0/dbus/dbus.h:30:2: error: #error "Please define
DBUS_API_SUBJECT_TO_CHANGE to acknowledge your understanding that D-Bus
/hasn't reached 1.0 and is subject to protocol and API churn. See the README
for a full explanation."
make[3]: *** [gui.o] Error 1
make[3]: Leaving directory `/home/marco/svn-gnome/gimp/trunk/app/gui'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/marco/svn-gnome/gimp/trunk/app'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/marco/svn-gnome/gimp/trunk'
make: *** [all] Error 2
I'm able to compile again inserting
#define DBUS_API_SUBJECT_TO_CHANGE
in app/gui/gui.c
but I do not think this is the correct way I should follow to compile...
Resolving this error I get another error:
Making all in po-libgimp make[2]: Entering directory `/home/marco/svn-gnome/gimp/trunk/po-libgimp' Makefile:159: *** target pattern contains no `%'. Stop. make[2]: Leaving directory `/home/marco/svn-gnome/gimp/trunk/po-libgimp' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/marco/svn-gnome/gimp/trunk' make: *** [all] Error 2
Exaclty on the po files where I see the problem, perhaps resolving this fixes it all...
On Wed, 2007-02-07 at 09:12 +0100, Marco Ciampa wrote:
In file included from /usr/include/dbus-1.0/dbus/dbus-glib-lowlevel.h:28, from gui.c:27:
/usr/include/dbus-1.0/dbus/dbus.h:30:2: error: #error "Please define DBUS_API_SUBJECT_TO_CHANGE to acknowledge your understanding that D-Bus /hasn't reached 1.0 and is subject to protocol and API churn. See the README for a full explanation."
make[3]: Leaving directory `/home/marco/svn-gnome/gimp/trunk/app/gui' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/marco/svn-gnome/gimp/trunk/app' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/marco/svn-gnome/gimp/trunk' make: *** [all] Error 2I'm able to compile again inserting
in app/gui/gui.c
That's another issue. The problem here is that your version of D-Bus is too old. But I think we should add the #define until we decide to depend on a newer version of D-Bus and add a configure check for it.
Yes, that might very well fix the problem for you. I remember that I used to have this issue with the po-libgimp Makefiles myself. Now if only I could remember how I fixed it...
As of current po-libgimp/it.po
#: ../modules/cdisplay_colorblind.c:67 msgid "Protanopia (insensitivity to red)" msgstr "Protanopia (insensibilità al rosso)"
Alexandre
Perhaps may help if I post the source lines of the Makefile that trigger the error:
all: all-yes
all-yes: $(CATALOGS) all-no:
#here is the problem!
$(GETTEXT_PACKAGE).pot: $(POTFILES)
$(GENPOT)
TIA
So, do you know if ther eis an Italian word for it,a nd which it is? If there are proper Italian words for that, just send then to the list and we will fix(exceptionally, the normal course would be to ask for the change in bugzilla.gimp.org)
I am the trasnaltor for Brazillian portuguese, and as far as I know these exact terms can be used in my language, so they are not changed in the pt_BR translation as well.
js ->
Alexandre
The terms are the same in italian (they actually come from Latin) so the translation is correct and complete, thanks.
See the other thread, perhaps the problem is in the automake/autoconf process that creates an invalid Makefile for the po-libgimp directory. I'm sorry, I'm not an expert in automake/autoconf/make so I do not know how should look a correct Makefile to handle correctly the compilation/update of these .po files.
bye
Hi Marco,
if I remember correctly this is fixed by removing the generated files POTFILES in all po subdirectories. Try this command in the toplevel gimp source directory:
find . -name POTFILES -exec rm {} \;
Then do a rebuild. The problem here is that the Makefile rules to generate the files used to be broken. We fixed the Makefiles but there's no dependency that would cause the broken files to be regenerated.
On Thu, Feb 08, 2007 at 07:40:53AM +0100, Sven Neumann wrote:
Hi Marco,
Great, it worked! Perhaps that operation could be insterted in the makefile with the command "make clean" (if it's not already present...)
Thanks again.
Hi Marco,
Sorry, I was too hasty. It worked for the compilation but the problem remains, as you can see here:
http://www.ciampix.net/screenshot.png
very strange, all the other messages looks translated...
No, it shouldn't. This was only necessary once after the Makefiles were changed (some weeks ago). You shouldn't have to do this again.
Not your fault. We forgot to set the translation domain for the enum. This is now fixed in trunk.
Great, thanks, THIS IS FEEDBACK!
I love you gimp developers!
