using layer/channel as mask
| using layer/channel as mask | Kevin Galligan | 22 Jan 19:34 |
| using layer/channel as mask | David Gowers | 25 Jan 02:30 |
| using layer/channel as mask | Kevin Galligan | 25 Jan 02:55 |
| using layer/channel as mask | David Gowers | 25 Jan 04:49 |
I've been trying to script something that seems relatively simple, yet I've spent the better part of today stuck at one little step. I have started naming things with curse words, so I figured I'd reach out for help before I start throwing things.
I have a layer that I want to serve as the mask for another layer. The values in the mask layer are white, so in theory, I could do the following...
;Somehow get the green Channel of the mask layer
(set! greenChannelMask [magicFunctionHere])
(gimp-layer-add-mask myLayer greenChannelMask)
I'm sure there's a more elegant way of doing it. If so, please let me know. However, if the above would work, I just need to know how to get that channel. Should be easy, but I have been beating my head agaist a wall. I just can't get it. I tried 'gimp-image-get-channels' in the console just to see if I could do it the hard way, but it always returns '(0 #()#0"")', no matter what image, which leads me to believe I don't understand how that function works. I also tried 'gimp-image-get-active-channel' in the console, but that comes back with -1. All the time.
I probably wouldn't be so frustrated if this was a big deal, but should be easy to get the channel, yet I've burned much of the day and have made no other progress (other than, of course, having nowhere else to look).
Thanks in advance, -Kevin
Sounds familiar .. although that's happened much less to me since I started using Python-Fu instead of Script-Fu.
The function returns a list of channels. ie. What you see in the bottom part of the Channels dialog.
Anyway, you don't really need to get the green values, just get the
intensity.
The way to do this is:
* Copy the mask layer (as in gimp-edit-copy -- or gimp-edit-named-copy if
you want to preserve the clipboard)
* Add a mask to the target layer *if needed*
* Paste onto the mask
* Anchor
I settled on that route after some wrestling...
*** CODE HERE *** (set! shadowMask (car(gimp-layer-create-mask shadowLayer ADD-ALPHA-MASK))) (gimp-layer-add-mask shadowLayer shadowMask)
        (gimp-selection-all inImage)
        (gimp-edit-copy inDrawable)
        (set! floatingSel (car (gimp-edit-paste shadowMask FALSE)))
        (gimp-floating-sel-anchor floatingSel)
(gimp-layer-remove-mask shadowLayer MASK-APPLY) *** ***
I hate scheme. I had to do scheme while in school for a class, and I just never, ever liked it. However, I don't think my problem here was with scheme (after, obviously, the initial refresher). It was getting my head around the api. I still don't know how to get a reference to the color channel (green, blue, or red. Didn't matter. Just needed the values).
Do you have a good link to coding python and gimp? I found some stuff, but it seemed old, and I wound up sticking with scheme.
Anyway, you don't really need to get the green values, just get the intensity.
The way to do this is:* Copy the mask layer (as in gimp-edit-copy -- or gimp-edit-named-copy if you want to preserve the clipboard)
* Add a mask to the target layer *if needed* * Paste onto the mask
* Anchorthe console, but that comes back with -1. All the time.
(gimp-selection-all inImage) (gimp-edit-copy inDrawable)
(set! floatingSel (car (gimp-edit-paste shadowMask FALSE))) (gimp-floating-sel-anchor floatingSel)(gimp-layer-remove-mask shadowLayer MASK-APPLY)
Is it your intention to apply the mask incrementally? Every time you apply the mask, that will reduce the alpha of the pixels in shadowlayer. in short, outAlpha = inAlpha * maskValue.
You cannot.
If you want to use the 'decompose' plugin to separate the component of an
image, or use Python's advanced slicing to extract data for one component
from the entire pixel data, you can do that.
On Windows it is slightly more complicated to get Gimp working with Python-Fu. On Linux, it's pretty simple -- just run ./configure with the --enable-python switch (this is enabled by default in recent versions), then rebuild and reinstall. Then you can write plugins and put them in your gimp plugins directory. A simple plugin is attached.
