add mouse action for brush scaling
add mouse action for brush scaling Alexander Rabtchevich 24 Jan 10:32
  add mouse action for brush scaling Thorsten Wilms 24 Jan 11:02
   add mouse action for brush scaling Alexander Rabtchevich 24 Jan 17:22
2007-01-24 10:32:03 UTC (about 18 years ago)
Currently scalable brush can be scaled with [ ] by default, what is very fine. Could a mouse scroll wheel + some key modifier be used to act the same as [ ] buttons?
I'm a right-handed person, so when I retouch a photo most of my actions are connected with mouse movements and some left hand actions: Ctr+H, Ctrl+C, Ctrl+wheel, Shift+wheel, Space. Rather often brush needs to be scaled, so I have to left mouse and press [ or ] several times. The left side of the keyboard is mostly taken with shotcuts.
I suggest adding Alt + wheel to act like [ ] for brush scaling. It could be very convenient to a user not to leave a mouse for keyboard and due the wheel is very well controllable and intuitive for scaling purposes.
Thorsten Wilms
2007-01-24 11:02:14 UTC (about 18 years ago)
I couldn't find it in the shortcut editor (maybe I overlooked it). It should be listed there, right?
Hmm, Alt + wheel is mapped to opacity. Ctrl + wheel zooms.
Shift + wheel scrolls sideways.
While I prefer + and - for zooming, I guess some people would complain if ctrl + wheel got remapped.
Preferences -> Input Controlers allows to map mouse wheel events to actions, but I don't see actions for changing brush size.
Ctrl + Alt + wheel cycles through gradients. Shift + Alt + whell cycles through patterns. Shift + Ctrl + wheel cycles through brushes.
I think the last 3 are quite odd, but 2 keys plus wheel isn't exactly comfortable anyway, so I guess you wouldn't want an often used feature there.
Thorsten Wilms
Thorwil's Creature Illustrations: http://www.printfection.com/thorwil
2007-01-24 17:22:47 UTC (about 18 years ago)
build
As I understand, it appeared there by default in 2.3.11 or other build close to it . Before it was possible to assign these keys manually in developers branch (and I did it).
Ctrl+wheel, wheel itself, shift+wheel and space form a pretty complete set of picture movement and scaling. I like it and suffer then any other program doesn't provide wheel and Ctrl+wheel.
Thank you for solution to the problem. I've assigned Alt+wheel to context->brush-radius-decrease and context->brush-radius-increase and feel myself happy for now :).
