Marketing for 2.4
Marketing for 2.4 cedric GEMY 18 Jan 20:56
  Marketing for 2.4 David Gowers 18 Jan 22:58
   Marketing for 2.4 Alex Pounds 19 Jan 00:08
  Marketing for 2.4 Sven Neumann 19 Jan 09:05
cedric GEMY
2007-01-18 20:56:16 UTC (over 18 years ago)
Marketing for 2.4
Some weeks ago, i've involved on Irc to do a kind of Gimp brochure to show new functionnalities, one in the style i already made for Scribus or Inkscape. You can get it at http://www.le-radar.com/temp/Brochure2-4b.pdf
I reached the step where it needs some proofing : - my english is not perfect at all ;) - may be some things should be changed - may be some things should be added
All the comments are welcome.
+ need to save space for a general gimp description.
NB : Please read this with a good pdf reader because of transparency issues.
Cedric
David Gowers
2007-01-18 22:58:08 UTC (over 18 years ago)
Marketing for 2.4
Okay, here are my corrections:
"EXIF ans XMP support" ans->and "EXIF metadata are used by many cameras to sum up its settings" -> "EXIF metadata is used by many cameras to describe the settings a picture was taken with" -- perhaps a little long. just the 'are->is' replacement would be good then
'makes it a realty' -> 'make it a reality'
'Gimp's plug-ins are no more organized due' more->longer 'in the same time' -> 'at the same time'
The Heal tool preview is not a preview of the heal tool, just a copy of the perspective clone images.
'extract object from a background' -> 'extract an object from a picture' 'older Gimp's release' -> 'older Gimp releases'
I enjoy the use of the word 'graphists'. It is not an English word though. English might say 'graphic artists'.
Alex Pounds
2007-01-19 00:08:57 UTC (over 18 years ago)
Marketing for 2.4
Grammar Nazis will tell you never to end a sentence with a preposition; this is better treated as a guideline than an inviolable rule. If you're ending a sentence with one, than it would probably be better reworked:
"Many cameras use EXIF metadata to describe the settings used to take the picture."
This is just a suggestion, of course.
2007-01-19 09:05:52 UTC (over 18 years ago)
Marketing for 2.4
That is doubling the effort of Jakub and Karine who, as far as I know, are also working on the 2.4 release notes. Shouldn't you make this a coordinated effort?
Your brochure mentions handling of metadata, but I am afraid that this feature is most likely not going to make it into 2.4. This might still change but currently there is not much working code available.
