How to get if the buffer is empty or not
How to get if the buffer is empty or not Bart 18 Jan 13:31
  How to get if the buffer is empty or not David Gowers 18 Jan 14:27
  How to get if the buffer is empty or not Sven Neumann 18 Jan 16:23
  How to get if the buffer is empty or not Bart 22 Jan 13:28
Bart
2007-01-18 13:31:19 UTC (almost 19 years ago)
i'm developing a script that insert the clipboard as a layer (its based on older existing scripts) and to avoid error messages to the user i'd like to check up wether the clipboard is empty or not. How to do that?
If you interested this script could bundeled with next version of Gimp. I register it to "Image/Edit/Paste as" like "Paste as brush" or "Paste as Pattern".
Thanx.
Karamba! Bart.
David Gowers
2007-01-18 14:27:28 UTC (almost 19 years ago)
Maybe Script-fu has a similar capability, anyway this is natural to express in Python:
try:
floating = pdb.gimp_edit_paste(image.active_layer, False) except RuntimeError:
# code that executes if gimp_edit_paste causes a runtime error goes here. I would expect this to just be the following: return
2007-01-18 16:23:16 UTC (almost 19 years ago)
Huh? How is that different to what Edit->Paste does?
You can't easily do that. However the error messages are of course a bug and IIRC there's a bug report for this. Most probably even on the 2.4 milestone.
Bart
2007-01-22 13:28:42 UTC (over 18 years ago)
does anybody know how gimp-buffer-list in SCM-script work when try to get the number off buffers in a variable? I didn't get it work.
Thanx.
Karamba! Bart
> __________
Thanx.
Karamba! Bart.
