"seamless texture painting: draw tool "warping across" image border"
"seamless texture painting: draw tool "warping across" image border" David Gowers 08 Jan 03:25
  "seamless texture painting: draw tool "warping across" image border" Sven Neumann 08 Jan 08:29
David Gowers
2007-01-08 03:25:34 UTC (about 18 years ago)
http://bugzilla.gnome.org/show_bug.cgi?id=392613
My thoughts:
* The warping must be done inside of the stroke interpolator, to handle wrapping correctly (eg. when you paint off the right edge onto the left)
* During painting, a good UI would be to expose the tile currently being painted on.
That is:
I
if I is the image, and the user paints off to the right:
II
and then down by the image height
II I
and left by the image width
II
II
then stops painting:
I
* Ideally, it would apply to all paint tools and all sampling tools (so eg. you could use it with Levels, Curves, Eyedropper, ).
* It would be nice to have it applicable to Fuzzy Select, but probably more work. Same for transformation tools.
2007-01-08 08:29:26 UTC (about 18 years ago)
Before we go into details, could we try to find out what this feature would actually be good for and if we want to support it? You already figured that it's quite an intrusive change and needs support all over the place.
There are already two quite different suggestions in our bug-tracker that deal with the problem of texture painting (see http://bugzilla.gnome.org/show_bug.cgi?id=327175). So it seems to make sense to think about this more. Who actually needs this feature and how is it going to be used?
