PATCH: Add HSL to compose/decompose plugins
| PATCH: Add HSL to compose/decompose plugins | Robert L Krawitz | 06 Jan 20:05 |
| PATCH: Add HSL to compose/decompose plugins | Sven Neumann | 06 Jan 20:11 |
| PATCH: Add HSL to compose/decompose plugins | Robert L Krawitz | 06 Jan 20:41 |
| PATCH: Add HSL to compose/decompose plugins | Robert L Krawitz | 06 Jan 20:43 |
| PATCH: Add HSL to compose/decompose plugins | Robert L Krawitz | 06 Jan 20:58 |
The attached patch (against 2.3.13) adds support for the HSL color space to compose/decompose. In my experience, HSL is often a better color space for manipulation than HSV; it better reflects our perception than HSV. An example is a photo I'm currently working on of a red leaf backlit against a blue sky; I'm trying to balance the leaf against the sky. The leaf is perceptually considerably darker than the sky (which is reflected well in luminosity), but the values of the leaf and the sky are very similar, making it hard to correct via curves. As a result, this is not difficult to correct in HSL space, but is very difficult to enhance in HSV.
Note that the definition of saturation is a bit different in HSL vs. HSV.
In Gutenprint we use another color space for corrections, HLK (hue/luminosity/black). K is defined in the usual way of min(C,M,Y) (white would be defined as min(R,G,B)). The H and L components are then computed from the residual; S is implicitly 1 since min is zero (and L is never greater than 0.5, for the same reason, so a reasonable HLK space would double the L value). This is more useful for CMYK printing than it likely is for RGB image manipulation; it allows us to correct the properties of the color inks without affecting the black generation, as would otherwise happen if we were to use HSL space (and it also simplifies the color correction since we don't have to worry about saturation). This was one of the major advances in color correction we made in 5.0. I'd be happy to code it up if people are interested.
--- ./libgimpcolor/gimpcolorspace.c~	2006-06-27 06:33:48.000000000 -0400
+++ ./libgimpcolor/gimpcolorspace.c	2007-01-06 13:07:51.000000000 -0500
@@ -1003,6 +1003,85 @@
+ * gimp_rgb_to_hsl4:
+ * @rgb:        RGB triplet, rgb[0] is red channel, rgb[1] is green,
+ *              rgb[2] is blue (0..255)
+ * @hue:        Pointer to hue channel (0..1)
+ * @saturation: Pointer to saturation channel (0..1)
+ * @luma:       Pointer to luma channel (0..1)
+void
+gimp_rgb_to_hsl4 (const guchar *rgb,
+                  gdouble      *hue,
+                  gdouble      *saturation,
+                  gdouble      *luma)
+  gdouble red, green, blue;
+  gdouble h, s, l;
+  gdouble min, max;
+  gdouble delta;
+  red   = rgb[0] / 255.0;
+  green = rgb[1] / 255.0;
+  blue  = rgb[2] / 255.0;
+  h = 0.0; /* Shut up -Wall */
+  if (red > green)
+      max = MAX (red,   blue);
+      min = MIN (green, blue);
+  else
+      max = MAX (green, blue);
+      min = MIN (red,   blue);
+  l = (max + min) / 2.0;
+  if (max == min)
+      s = 0.0;
+      h = GIMP_HSL_UNDEFINED;
+  else
+      if (l < 0.0)
+        h += 1.0;
+  *hue        = h;
+  *saturation = s;
+  *luma       = l;
  * gimp_hsv_to_rgb4:
@@ -1083,3 +1162,40 @@
   rgb[1] = ROUND (saturation * 255.0);
   rgb[2] = ROUND (value      * 255.0);
+ * gimp_hsl_to_rgb4:
+ * @hue:        Hue channel (0..1)
+ * @saturation: Saturation channel (0..1)
+ * @luma:      Luma channel (0..1)
+void
+gimp_hsl_to_rgb4 (guchar  *rgb,
+                  gdouble  hue,
+                  gdouble  saturation,
+                  gdouble  luma)
+  if (saturation == 0.0)
+      hue        = luma;
+      saturation = luma;
+      luma       = luma;
+  else
+      gdouble m1, m2;
+      if (luma  0)
+      gimp_rgb_to_hsl4 (rgb_src, &hue, &sat, &val);
+      *hue_dst++ = (guchar) (hue * 255.999);
+      *sat_dst++ = (guchar) (sat * 255.999);
+      *lum_dst++ = (guchar) (val * 255.999);
+      rgb_src += offset;
+static void
+extract_huel (const guchar  *src,
+	     gint           bpp,
+	     gint           numpix,
+	     guchar       **dst)
+  register const guchar *rgb_src = src;
+  register guchar *hue_dst = dst[0];
+  register gint count = numpix, offset = bpp;
+  gdouble hue, dummy;
+  while (count-- > 0)
+      gimp_rgb_to_hsl4 (rgb_src, &hue, &dummy, &dummy);
+static void
+extract_satl (const guchar  *src,
+	     gint           bpp,
+	     gint           numpix,
+	     guchar       **dst)
+  register guchar *sat_dst = dst[0];
+  gdouble sat, dummy;
+      gimp_rgb_to_hsl4 (rgb_src, &dummy, &sat, &dummy);
+static void
+extract_luma (const guchar  *src,
+	      gint           bpp,
+	      gint           numpix,
+	      guchar       **dst)
+  register guchar *lum_dst = dst[0];
+  gdouble lum, dummy;
+      gimp_rgb_to_hsl4 (rgb_src, &dummy, &dummy, &lum);
+      *lum_dst++ = (guchar) (lum * 255.999);
+static void
 extract_cyan (const guchar  *src,
 	      gint           bpp,
 	      gint           numpix,
--- ./plug-ins/common/compose.c~	2006-09-01 07:14:34.000000000 -0400
+++ ./plug-ins/common/compose.c	2007-01-06 13:08:52.000000000 -0500
@@ -93,6 +93,11 @@
                                       gint             numpix,
                                       guchar          *dst,
                                       gboolean         dst_has_alpha);
+static void      compose_hsl         (guchar         **src,
+                                      gint            *incr,
+                                      gint             numpix,
+                                      guchar          *dst,
+                                      gboolean         dst_has_alpha);
 static void      compose_cmy         (guchar         **src,
                                       gint            *incr,
                                       gint             numpix,
@@ -211,6 +216,14 @@
     { NULL, NULL, NULL, NULL },
     "hsv-compose",  compose_hsv },
+  { N_("HSL"), 3,
+    { N_("_Hue:"),
+      N_("_Saturation:"),
+      N_("_Luma:"),
+      NULL },
+    { NULL, NULL, NULL, NULL },
+    "hsl-compose",  compose_hsl },
   { N_("CMY"), 3,
     { N_("_Cyan:"),
       N_("_Magenta:"),
@@ -337,7 +350,7 @@
     { GIMP_PDB_IMAGE,    "image2",       "Second input image" },
     { GIMP_PDB_IMAGE,    "image3",       "Third input image" },
     { GIMP_PDB_IMAGE,    "image4",       "Fourth input image" },
-    { GIMP_PDB_STRING,   "compose-type", "What to compose: RGB, RGBA, HSV, CMY, CMYK" },
+    { GIMP_PDB_STRING,   "compose-type", "What to compose: RGB, RGBA, HSV, HSL, CMY, CMYK" },
     { GIMP_PDB_INT8,     "value1",       "Mask value if image 1 is -1" },
     { GIMP_PDB_INT8,     "value2",       "Mask value if image 2 is -1" },
     { GIMP_PDB_INT8,     "value3",       "Mask value if image 3 is -1" },
@@ -357,7 +370,7 @@
     { GIMP_PDB_DRAWABLE, "drawable2",    "Second input drawable" },
     { GIMP_PDB_DRAWABLE, "drawable3",    "Third input drawable" },
     { GIMP_PDB_DRAWABLE, "drawable4",    "Fourth input drawable" },
@@ -1035,6 +1048,38 @@
 static void
+compose_hsl (guchar **src,
+             gint    *incr_src,
+             gint     numpix,
+             guchar  *dst,
+  register const guchar *hue_src = src[0];
+  register const guchar *sat_src = src[1];
+  register const guchar *lum_src = src[2];
+  register       guchar *rgb_dst = dst;
+  register       gint    count   = numpix;
+  gint hue_incr = incr_src[0];
+  gint sat_incr = incr_src[1];
+  gint lum_incr = incr_src[2];
+      gimp_hsl_to_rgb4 (rgb_dst, (gdouble) *hue_src / 255.0,
+			         (gdouble) *sat_src / 255.0,
+			         (gdouble) *lum_src / 255.0);
+      rgb_dst += 3;
+      hue_src += hue_incr;
+      sat_src += sat_incr;
+      lum_src += lum_incr;
+      if (dst_has_alpha)
+        rgb_dst++;
+static void
              gint    *incr_src,
              gint     numpix,
the new function in libgimpcolor needs to be marked as new in 2.4. You can do that by adding "Since: GIMP 2.4" as the last line in the gtk-doc comment. The gtk-doc comment also lacks a description of what the function does. If that is corrected, I think we can still include this patch for 2.4.
   Date: Sat, 06 Jan 2007 20:11:06 +0100
Where does this go? Does it go in here somewhere?
 * gimp_hsl_to_rgb4:
BTW, I believe I also have to add appropriate lines to gimpcolor.def, correct?
   Cc: gimp-developer@lists.xcf.berkeley.edu
Never mind, I figured it out.
+++ ./libgimpcolor/gimpcolorspace.c	2007-01-06 14:57:28.000000000 -0500
@@ -1003,6 +1003,90 @@
+ * Convert an RGB color value to an HSL (Hue, Saturation, Lightness)
+ * color value.
+ * Since: GIMP 2.4
+void
+                  gdouble      *hue,
+                  gdouble      *luma)
+  gdouble h, s, l;
+  gdouble min, max;
+  gdouble delta;
+  if (red > green)
+  else
+  if (max == min)
+      s = 0.0;
+  else
+      if (l < 0.0)
+        h += 1.0;
+  *hue        = h;
+  *saturation = s;
+  *luma       = l;
  * gimp_hsv_to_rgb4:
@@ -1083,3 +1167,45 @@
+ * Convert an HSL color value (Hue, Saturation, Lightness) to an RGB
+ * color value.
+ * Since: GIMP 2.4
+void
+                  gdouble  hue,
+                  gdouble  luma)
+      hue        = luma;
+      luma       = luma;
+  else
+      gdouble m1, m2;
+      if (luma  0)
+static void
+	     gint           bpp,
+	     gint           numpix,
+	     guchar       **dst)
+static void
+	     gint           bpp,
+	     gint           numpix,
+	     guchar       **dst)
+static void
+	      gint           bpp,
+	      gint           numpix,
+	      guchar       **dst)
+static void
 	      gint           bpp,
 	      gint           numpix,
@@ -93,6 +93,11 @@
                                       gint             numpix,
                                       guchar          *dst,
+                                      gint            *incr,
+                                      gint             numpix,
+                                      guchar          *dst,
                                       gint            *incr,
                                       gint             numpix,
+  { N_("HSL"), 3,
+    { N_("_Hue:"),
+      N_("_Luma:"),
+      NULL },
   { N_("CMY"), 3,
     { N_("_Cyan:"),
       N_("_Magenta:"),
@@ -337,7 +350,7 @@
@@ -357,7 +370,7 @@
 static void
+             gint    *incr_src,
+             gint     numpix,
+             guchar  *dst,
+      rgb_dst += 3;
+        rgb_dst++;
+static void
              gint    *incr_src,
              gint     numpix,
