gimp source code repository migrated to subversion
gimp source code repository migrated to subversion Sven Neumann 30 Dec 14:21
  gimp source code repository migrated to subversion Sven Neumann 30 Dec 14:23
  gimp source code repository migrated to subversion Christoph Sturm 30 Dec 14:27
  gimp source code repository migrated to subversion Sven Neumann 30 Dec 15:18
2006-12-30 14:21:07 UTC (over 18 years ago)
you probably already know about it, but just in case that you don't...
The GNOME CVS repository is being migrated to Subversion while I am writing these lines. gimp was one of the first modules to be migrated and is already available on svn.gnome.org. The command to check out the trunk (this is the equivalent of the HEAD branch in CVS) is:
svn checkout http://svn.gnome.org/svn/gimp/
In order to check out the gimp-2-2 branch, you would use:
svn checkout http://svn.gnome.org/svn/gimp/branches/gimp-2-2
Working with Subversion is quite similar to working with CVS. Still, you will want to yourself familiar with the differences. A good resource is the Subversion book, available online at http://svnbook.red-bean.com/
2006-12-30 14:23:58 UTC (over 18 years ago)
Oops. That's the command to check out the whole tree, including all branches. Sorry for the mistake. This should have read instead:
svn checkout http://svn.gnome.org/svn/gimp/trunk
Christoph Sturm
2006-12-30 14:27:51 UTC (over 18 years ago)
hey!
http://svn.gnome.org/svn/gimp/trunk/ is the correct url
-chris
2006-12-30 15:18:11 UTC (over 18 years ago)
looks like we also already have write access to the Subversion server now. If you actually want to commit to the repository, you will have to check out the tree using ssh. The URL for trunk is then
svn+ssh://svn.gnome.org/svn/gimp/trunk
