Question abt compling GIMP
5 of 7 messages available
b66ddc900611281004t7da7bcb4... 07 Oct 20:24
  Question abt compling GIMP Alexandre Prokoudine 28 Nov 19:11
   Question abt compling GIMP Sven Neumann 29 Nov 10:35
    Question abt compling GIMP Alexandre Prokoudine 29 Nov 10:51
  Question abt compling GIMP Michael Natterer 28 Nov 19:42
b66ddc900611290813j5a2748ed... 07 Oct 20:24
  Question abt compling GIMP Michael Natterer 30 Nov 09:24
2006-11-28 19:11:40 UTC (over 18 years ago)
On 11/28/06, howard chen wrote:
I just want to modify a plugin file (*c) in the common folder, currently, when I modified the file, I use `make && make install` to compile, link and install the GIMP.
But this take some times to test the feature, are there any better method?
Make full compilation. Then, after, changing the plug-in file, remove relevant .o file and rerun 'make && make install' that will recompile the plugin again.
Alexandre
Michael Natterer
2006-11-28 19:42:08 UTC (over 18 years ago)
Yes, you can say "make plugin" and "make install-plugin", you don't need to build and install the entire common/ folder each time.
ciao, --mitch
2006-11-29 10:35:34 UTC (over 18 years ago)
But this will take forever. Instead, say your plug-in is called foo.c, you can use 'make -C plug-ins/common foo' to build and 'make -C plug-ins/common install-foo' to install the plug-in. Unless you change the procedure registration, you don't even need to restart GIMP to test your changes.
2006-11-29 10:51:13 UTC (over 18 years ago)
That's a very useful advice, thanx a lot!
Alexandre
Michael Natterer
2006-11-30 09:24:03 UTC (over 18 years ago)
ciao, --mitch
i tried... but it said...
==> no rule to make target `plugin` stop
in fact, i can't find the target `plugin` in the Makefile
Of course "plugin" is just a placeholder, I suggest you use the name of the plugin you want to compile.
another question: how to print out some debug message in the GIMP program?
The same way you would add debugging in any other program.
ciao, --mitch
