Successfull compile, will not run
Successfull compile, will not run Milos Prudek 27 Nov 13:43
  Successfull compile, will not run Simon Budig 27 Nov 16:43
   Successfull compile, will not run Michael Natterer 27 Nov 16:51
    Successfull compile, will not run Milos Prudek 27 Nov 21:15
Milos Prudek
2006-11-27 13:43:05 UTC (over 18 years ago)
After successfully compiling gimp-2.3.13, on Mandriva 2007.0, Gimp fails to run with this error message:
/usr/local/bin/gimp-2.3: symbol lookup error: /usr/local/bin/gimp-2.3: undefined symbol: gimp_vectors_stroke_type_get_type
Should I file a bug report?
Simon Budig
2006-11-27 16:43:07 UTC (over 18 years ago)
Please try 'ldd /usr/local/bin/gimp-2.3' first to verify that gimp does pick up the correct libraries on startup. I suspect a broken installation here.
Bye,
Simon
Michael Natterer
2006-11-27 16:51:26 UTC (over 18 years ago)
And note that you can *not* have gimp 2.2 in /usr and gimp 2.3 in /usr/local. 2.3 is supposed to replace 2.2, and /usr/local is *not* a totally separate prefix.
Use something like /opt or get rid of gimp 2.2 in /usr
ciao, --mitch
Milos Prudek
2006-11-27 21:15:24 UTC (over 18 years ago)
Your advice helped. Gimp starts. Thank you.
But the UI is in English, even though my enviro variables are set for Czech. Has Czech been disabled for this dev version?
