gimp-2.3.12 / win32 / python
gimp-2.3.12 / win32 / python lode leroy 31 Oct 09:21
lode leroy
2006-10-31 09:21:16 UTC (over 18 years ago)
I'm having problems with the python support in gimp-2.3.12...
I installed the following packages:
gtk+-2.10.6-setup.zip python-2.4.4.msi
pycairo-1.0.2-1.win32-py2.4.exe
pygtk-2.8.6-1.win32-py2.4.exe
gimp-2.3.12-i586-setup.zip
When I run the script "Xtns->Python-Fu->Test->Sphere", it works perfectly when I close the generated window in between tests. When I leave the new window open, the python plugin locks up after clicking the "OK" button.
Is this a know problem, or am I doing something wrong?
I used to use gimp-2.3.9+ActivePython+gtk+-2.8.6 which worked fine.... (or is pygtk-2.8 not working with gtk+-2.10)
any thoughts? thanks.
-- lode
__________________
