help on plugin compilation for Windows
help on plugin compilation for Windows Alexander Rabtchevich 04 Oct 15:37
  help on plugin compilation for Windows Hans Breuer 04 Oct 21:12
   help on plugin compilation for Windows Alexander Rabtchevich 08 Oct 13:57
  help on plugin compilation for Windows Michael Schumacher 08 Oct 14:20
   help on plugin compilation for Windows Alexander Rabtchevich 08 Oct 16:55
2006-10-04 15:37:35 UTC (over 18 years ago)
I've compiled the current version of fblur plug-in for Windows. But when engaged, it complies: Pango-warning. Couldn't load font Tahoma italic 8... The plug-in works with Gimp 2.3.11, GTK 2.8.18.
There is no font definitions in the source code of the plug-in. Ive used the following versions of libraries: cairo-dev-1.0.4.zip
cairo-1.0.4.zip
gtk+-dev-2.8.15.zip
gtk+-2.8.15.zip
pango-1.10.3.zip
pango-dev-1.10.3.zip
glib-2.8.6.zip
glib-dev-2.8.6.zip
zlib123-dll.zip
libpng-1.2.8-bin.zip
gettext-0.14.5.zip
gettext-dev-0.14.5.zip
libiconv-1.9.1.tar.gz
libiconv-1.9.1.bin.woe32.zip
pkg-config-0.20.zip
atk-1.10.3.zip
atk-dev-1.10.3.zip
gimp-dev-2.2.7.zip
Is there the problem in some library version?
Hans Breuer
2006-10-04 21:12:25 UTC (over 18 years ago)
There is no font definitions in the source code of the plug-in. Ive used the following versions of libraries: [...]
pango-1.10.3.zip
Pango can synthesize font variants since 1.12.x, so updating should help, see also: http://bugzilla.gnome.org/show_bug.cgi?id=110521
Hans
-------- Hans "at" Breuer "dot" Org ----------- Tell me what you need, and I'll tell you how to get along without it. -- Dilbert
2006-10-08 13:57:28 UTC (over 18 years ago)
Replacing libraries and headers with all the latest versions from Tor's win32 Gimp page hasn't helped. Maybe the cause is gimp 2.2.7 dev?
pango-1.10.3.zip
Hans
2006-10-08 14:20:27 UTC (over 18 years ago)
I've never seen such problems with my build and never heard that anyone else did. You can find the plug-ins I've built at
http://schumaml.gmxhome.de/downloads/gimp/
HTH, Michael
2006-10-08 16:55:10 UTC (over 18 years ago)
Thank you, Michael
I've downloaded and tried your compilation of fblur 2.3. It works without such a message. I don't know what to think.
There is a difference with my compilation in preview: your compilation shows standard behavior and my compilation displays two preview windows: one for the whole image (right) with movable selection area and the second (left) for the actual preview. P.S. Trying to browse for the brushes in the model tab causes gimp error message (translated): Error PDB calling for the procedure 'gimp-brushes-popup':
Argument 'opacity' (#4, type gdouble) is out of the range (the check has changed '-1.000000' to '0.000000')
HTH, Michael
