hot to continue with the heal tool
hot to continue with the heal tool Michael Natterer 04 Sep 14:57
  hot to continue with the heal tool Marco Ciampa 04 Sep 15:09
  hot to continue with the heal tool Kevin Sookocheff 04 Sep 16:45
Michael Natterer
2006-09-04 14:57:58 UTC (over 18 years ago)
Hi Kevin,
as you may have noticed, I merged the heal tool branch to CVS head. After that, I factored the parts of the clone tool that are almost identical in the heal tool out to new parent classes, GimpSourceCore, GimpSourceOptions and GimpSourceTool, and ported the clone core/options/tool to use the new parent class.
I've done the same for the heal core and tool, you can see the patch here:
http://mitch.gimp.org/heal-tool-ported-to-source-tool.patch
So, how do we continue from here...
Do you like the patch and do you want to commit it, or should i commit it? (given you like it :-)
Do you plan to do further hacking on the tool?
Also, WRT heal/clone from other images and from the projection, I think that code can nicely be abstracted into GimpSourceTool and GimpSourceTool's virtual motion() function extended by some parameters. What do you think about this?
ciao, --mitch
Marco Ciampa
2006-09-04 15:09:37 UTC (over 18 years ago)
On Mon, Sep 04, 2006 at 02:57:58PM +0200, Michael Natterer wrote:
Hi Kevin,
[cut]
Am I missing something or there are several internationalized strings missing?
(a translator without patience.. :-)
Kevin Sookocheff
2006-09-04 16:45:16 UTC (over 18 years ago)
Great!
Please go ahead and commit the patch. It looks great!
Unfortunately, I don't foresee being able to do any more work on this in the near future. I'm going to be moving to Kenya to start a one year internship in less than 2 weeks. There is a possibility that once I am settled I will be able to do some work, but right now I can't promise anything.
I think this would be the perfect place to abstract these operations.
Kevin
