Hard edged Ink tool?
37 of 37 messages available
Hard edged Ink tool? David Gowers 25 Aug 12:31
  Hard edged Ink tool? Sven Neumann 25 Aug 17:45
   Hard edged Ink tool? David Gowers 25 Aug 18:27
    Hard edged Ink tool? David Gowers 25 Aug 18:58
     Hard edged Ink tool? Sven Neumann 29 Aug 08:30
      Hard edged Ink tool? David Gowers 29 Aug 14:30
    Hard edged Ink tool? Sven Neumann 29 Aug 08:25
     Hard edged Ink tool? David Gowers 29 Aug 10:08
     Hard edged Ink tool? Henning Makholm 29 Aug 11:31
      Hard edged Ink tool? Øyvind Kolås 29 Aug 14:27
       Hard edged Ink tool? David Gowers 29 Aug 15:14
       Hard edged Ink tool? Henning Makholm 29 Aug 15:14
        Hard edged Ink tool? David Gowers 29 Aug 15:44
        Hard edged Ink tool? Simon Budig 29 Aug 15:53
         Hard edged Ink tool? David Gowers 29 Aug 16:17
         Hard edged Ink tool? Øyvind Kolås 29 Aug 16:17
          Hard edged Ink tool? David Gowers 29 Aug 16:29
         Hard edged Ink tool? Henning Makholm 29 Aug 16:30
          Hard edged Ink tool? Øyvind Kolås 29 Aug 16:45
           Hard edged Ink tool? Henning Makholm 29 Aug 16:52
          Hard edged Ink tool? Øyvind Kolås 29 Aug 18:15
           Hard edged Ink tool? Henning Makholm 29 Aug 20:46
            Hard edged Ink tool? David Gowers 30 Aug 01:58
             Hard edged Ink tool? Henning Makholm 31 Aug 12:36
        Hard edged Ink tool? Sven Neumann 30 Aug 08:15
         Hard edged Ink tool? David Gowers 30 Aug 11:19
          Hard edged Ink tool? Sven Neumann 30 Aug 19:21
          Hard edged Ink tool? Henning Makholm 31 Aug 12:32
         Hard edged Ink tool? Henning Makholm 31 Aug 12:34
          Hard edged Ink tool? Sven Neumann 31 Aug 20:45
           Hard edged Ink tool? Henning Makholm 04 Sep 12:22
            Hard edged Ink tool? Alexandre Prokoudine 04 Sep 12:25
             Hard edged Ink tool? Sven Neumann 04 Sep 20:40
              Hard edged Ink tool? Alexandre Prokoudine 04 Sep 20:42
               Hard edged Ink tool? Michael Schumacher 04 Sep 21:10
               Hard edged Ink tool? Sven Neumann 05 Sep 07:39
            Hard edged Ink tool? Sven Neumann 04 Sep 20:37
David Gowers
2006-08-25 12:31:33 UTC (over 18 years ago)
Is there some simple way to achieve hard-edged rendering for the Ink tool? I find the hard edged rendering used in INDEXED mode best for drawing lineart, but dislike the other constraints (no drawing modes/opacity/layer modes) imposed by working in INDEXED mode. So far, I've tried to find the part of the code that handles indexed images without success, and enabled the Hard edge toggle for the Ink tool (which does nothing in this case, as I suspected -- it only applies to brush-based paint tools).
Is this code shared between tools? (for instance, the Airbrush behaves similarly in INDEXED mode)
Where would be a good place for me to look in order to implement this?
2006-08-25 17:45:00 UTC (over 18 years ago)
Should be a simple change, just turn off supersampling in the ink code.
Eeek, the way it acts in INDEXED mode is so ugly. Why would you want to do this?
So far, I've tried to find the part of the code that handles indexed images without success.
Why would you look for it? That's completely unrelated here. The ugly behaviour in indexed mode is just a shortcoming of the code that combines regions.
David Gowers
2006-08-25 18:27:09 UTC (over 18 years ago)
Ah, the #define SUBSAMPLE 8 line. Changing it to 1 does indeed do what I wanted.
Because it's easier to edit. If edges aren't defined in a binary way, it makes selecting portions of lineart and moving or removing them hard -- I have to set the threshold of whatever tool I'm using to a high value, but that high value will be not what I want for most of what I'm doing. I'm trying to avoid tedious fiddling.
Is there some specific part of the INDEXED behaviour that you are eeking about? I'm just looking for the hard edges.
It's good to know that. I previously got the impression that you were indifferent to GIMP's usefulness for editing INDEXED images. I certainly hope that I can substantially improve indexed drawing specifically, when GEGL is in use and I understand it. I think it would be relatively simple to bring INDEXED drawing to the level of usefulness demonstrated by professional pixeling tools (ProMotion, or the older DeluxePaint and it's clones) with a sound architecture like that.
David Gowers
2006-08-25 18:58:25 UTC (over 18 years ago)
Actually, I take that back. I'm looking for normal supersampling which is subsequently alpha-thresholded (exactly the way the ink and airbrush tools work in INDEXED mode.)
The behaviour of the Ink tool without supersampling is unacceptably chunky.
So it looks like this may not be possible :(
2006-08-29 08:25:50 UTC (over 18 years ago)
Gegl doesn't support images with indexed colors and I very much doubt that it ever will support it. It is rather likely that indexed mode will be completely handled by load and save plug-ins in a gegl-based GIMP. If there's a need for editing indexed mode, this need will likey have to be fulfilled by a different application then.
2006-08-29 08:30:48 UTC (over 18 years ago)
Well, of course changing the define is not what you want because then you can't get the old behaviour back.
What keeps you from thresholding the alpha values (which is essentially what the combine_regions code is doing, even though there is actually no goood reason for this behaviour)?
David Gowers
2006-08-29 10:08:32 UTC (over 18 years ago)
Ah. It's not so much a need, as the tools would be much faster in indexed mode (eg 'shade' mode -- painting that cause pixels to change to the next brighter or darker color in the palette). Naturally palette searching would be needed for that in RGB mode, as opposed to running the indice through a 256-entry lookup table.
However, I suspect that simply having a 'indexize'* op just before the display op in the graph would probably work well enough (possibly better, even).
*or 'quantize' -- whatever it would be called, where it receives RGB data and outputs quantized RGB data.
Henning Makholm
2006-08-29 11:31:01 UTC (over 18 years ago)
Scripsit Sven Neumann
Or rather, we who need indexed imaged would have to fork Gimp from the last sane version.
Øyvind Kolås
2006-08-29 14:27:11 UTC (over 18 years ago)
I wonder which version of GIMP that is, my version of GIMP is already crippled when it comes to supporting indexed images. I'm not allowed to create new images in indexed mode, I cannot set the opacity for a layer, I cannot use the smudge or blur|sharpen tool, gaussian blur doesn't work neither does unsharp mask, layer masks seems to work but get their alpha thresholded. To do any real work on an indexed image I already have to go by RGB.
Duplicating this behavior in GEGL would not be appropriate in my opinion, if an indexed image is loaded, the lookup table of the palette is interpreted and it is treated as a color image. Thus GEGL will have the same stance towards GIF/PCX as JPG, RAW and SVG, they might be included as source material verbatim, but expecting palette preserved, DCT level compositing, non-demosaiced bayer-data or vectors in the output,. after compositing and image processing, is quite simply outside the reasonable scope for a image processing/compositing library.
Adding capabilities outside GEGL that special cases editing of indexed drawables is of course an option, (in the same manner that the path tool or inkscape would be possible to invoke for operation on SVG based vector data.
/Øyvind K.
David Gowers
2006-08-29 14:30:03 UTC (over 18 years ago)
I can, apparently. Now I have only to make that behaviour optional.
David Gowers
2006-08-29 15:14:33 UTC (over 18 years ago)
I assume you meant GIF/PCX/PNG
I want it DURING compositing.
I was assuming that, until an indexed image had to be composited with a non-indexed image, its data could remain indexed. However, if the palette could be separately recovered from the original file (as another input to the compositing Op), so it could be used to govern blending behaviour, that would be equally practical.
Here's a little python docstring sketch of one of the the functions I was considering:
"""Shade -- Grafx2 style shading facility.
Colors are considered as indices by SHADE, even on a RGB source.
lut[NCOLORS] A Numpy array, the result of applying one step of shading
to COLOR. Should be precalculated to have the appropriate output format (RGB or RGBA or GRAY)
shadeable Dictionary color:index
Basic process: pixel = srcpixels[x,y]
color = hash(pixel[:3]) # ignore alpha try:
index = shadeable[color]
destpixels[x,y] = lut[index] except:
destpixels[x,y] = pixel
I'm sure you can see how it would be simplified and significantly sped up if I could just read indices, look their 'next color' up, and write the resultant indice.
Simply being able to get image data into an indexed form with some chosen palette(doesn't have to be the exact original) just before passing it through an Op like SHADE above, would work well for that. Is that kind of thing possible or likely to be supported?
That would address using SHADE above as a paint mode, maybe. With the Op-based paint application model that has been discussed here and on Bugzilla,
Henning Makholm
2006-08-29 15:14:53 UTC (over 18 years ago)
Scripsit "Øyvind Kolås"
A minor nuisance, easily worked around. Equally easy coded around in a fork.
A major nuisance.
Neither of which are something one usually needs in a situation where one wants to stick to a colormap while editing.
Your idea of "real work" is obviously very different from mine. I do lots of real work on indexed images.
I don't really care whether it is duplicated in GEGL or outside it, as long as the net effect of "don't let my editing result in pixel colors outside this small predeterined palette" is still attainable with the sum of GEGL + futureGimp.
David Gowers
2006-08-29 15:44:08 UTC (over 18 years ago)
Smudge and layer masks are two things that I would appreciate for indexed images. I already have workarounds which let me return the results to the appropriate palette quickly, that is how I found that out.
Yes.
opinion,
That is essentially what I want, too.
Henning Makholm "This imposes the restriction on any
procedure statement that the kind and type
of each actual parameter be compatible with the
kind and type of the corresponding formal parameter."
Is that quote meant to be hard to understand? Or just to demonstrate how awkward english can be?
Simon Budig
2006-08-29 15:53:48 UTC (over 18 years ago)
I wonder if a "quantize to palette" Gegl Op would solve these problems. In most of the cases when people are asking for an indexed palette, the palette is already determined somehow, either by importing from the image or by editing for a specific hardware or certain texture conventions.
In that case you really could have a "quantize" op, that maps all colors in the images to the appropriate colors in the palette. You'd have all the power of semitransparent layers, all tools would work as "expected" for a given definition of "expected" :), blurring would work etc.
I am pretty positive that these problems could be sorted out when we know what people working with palette-based images want to have. I am just guessing on the needs here...
Bye, Simon
David Gowers
2006-08-29 16:17:03 UTC (over 18 years ago)
That would work for me definitely. I use indexed mode for drawing pixel art. As long as that Op could be placed wherever I want it -- because antialiasing something, shading it, and then quantizing it is not the same as antialiasing it, quantizing it, shading it, and quantizing it again (the latter may be more effective.). I believe this would satisfy people who want to quantize to a >256 color palette (eg Pantone colors). I cannot comment on texture drawing.
I *would* want the palette to be saved with the image, because that makes color selection a lot easier -- I wouldn't have to try to select the right palette for the image before drawing on it.
Along a similar line of thinking, I've tried at various times to convince gimp's convert-indexed functionality to output RGB rather than indexed. I find the code somewhat confusing, but I think this is what I need to do:
* allocate RGB tiles instead of indexed ones. * write color values rather than indices
actually, that seems rather simple now. I'm marking all the changes needed in gimpimage-convert.c now. Thanks.
Øyvind Kolås
2006-08-29 16:17:14 UTC (over 18 years ago)
Having an implied conversion to RGB on input of indexed drawables is the way GEGL will currently deal with such images. Adding an op that converts this to 8bit/16bit/32bit integer grayscale with a predefined, or optimally computed R,G,B palette is the natural progression. That op could be used before saving/as a step towards displaying data.
This allows implementations of all other processing and compositing operations to be ignorant of indexed drawables, but is not an indexed workflow, it will not work when multiple of the original colors mapped to the same RGB triplet, but has a different interpretation.
/Øyvind K.
David Gowers
2006-08-29 16:29:34 UTC (over 18 years ago)
I believe that last thing is a minor issue that should be addressable by an output op; Certainly, actually editing with identical colors that have different indices is unhelpful and confusing. Some kind of custom remapping for a certain set of colors would probably be the way to go.
Henning Makholm
2006-08-29 16:30:22 UTC (over 18 years ago)
Scripsit Simon Budig
It would work for me, if the surrounding application allowed me to set as a layer or image property that I want that operation to be applied _immediately_ for each drawing operation I do.
My concrete need is that I edit bitmaps with a specific color convention - they can be seen e.g. at . I use a system of ad-hoc software to convert the bitmap source to the vector versions linked to below the image; this software depends on the exact colormap in the picture, because different colors should be vectorized in different ways.
[Before someone asks: yes, I have considered using a vector tool as the master editing format, but I have not found one whose user interface fits my way of working as well as Gimp does].
Now, when I edit in indexed mode I am sure that I don't accidentally give a pixel a color that is off the expected one by a delta that is too small for me to see. For example I sometimes accidentally select the airbrush or pen tool and draw something. I may not notice this until later, when it is too late to undo automatically, but at least with the implicit quantization it is immediately clear to me which pixels I need to repair manually. If I had worked in RGB mode I would need to wonder whether I had accidentally airbrushed something from 255/255/255 to 252/252/252, which is impossible to see by eye.
Essentially, indexed mode helps me by making sure that what I see is all I get. And does it *while* I edit: doing a separate quantization step at the end of my work and then going over all of the image in zoomed mode to look for glitches would be seriously bothersome.
Øyvind Kolås
2006-08-29 16:45:24 UTC (over 18 years ago)
snip<
Within the current gimp architecture you are asking for the job that op would be performing to be done in a display filter, with a fixed pallete (whilst working in RGB mode). This would cause all work being done on the image to be displayed with the reduced palette. Thus allow you to work "non-indexed" but see a reduced pallete result in realtime.
/Øyvind K.
Henning Makholm
2006-08-29 16:52:51 UTC (over 18 years ago)
Scripsit Øyvind Kolås
No - I don't only want to _see_ a reduced-palette result; I want to actually _get_ a reduced-palette result. With an action purely on the display level, I cannot see or correct inaccuracies on the underlying pixel data; I cannot be sure that when I use the colorpicker tool it is the standard color that I see that gets picked up, etc.
Additionally, it _would_ be rather cool to have the pixel data in each layer be quantized but still be able to select partial layer opacities while editing.
Øyvind Kolås
2006-08-29 18:15:05 UTC (over 18 years ago)
This need could be solved using layer-masks and threshold. Or to attack the problem with an unstable dialect of xml:
/Øyvind K.
Henning Makholm
2006-08-29 20:46:05 UTC (over 18 years ago)
I'm not sure I can see what you're getting at, but are you suggesting that I use a seperate layer for each color? That would make any kind of editing extremely painful.
David Gowers
2006-08-30 01:58:11 UTC (over 18 years ago)
When I saw it, I thought so too.
However, remember this is GEGL being discussed here. *GIMP* might well provide a way to back-propagate the result of an Op in the graph, which should take care of this okay.
By back-propagate i mean, you draw on a layer, it get quantized before display -- and you can propagate that change back to the original layer. It seems a highly desireable option to me, even for non-quantized images.
(nor is GEGL in any way suited to implement back-propagation of the sort you described. It goes against its data model; Whereas this is suitable for GIMP to implement.)
2006-08-30 08:15:06 UTC (over 18 years ago)
Perhaps you should write up a summary then that explains your workflow on real world examples. At the moment we are talking about "indexed images" and probably mean "how indexed images are currently treated in GIMP". But what exactly is it that you need? Is it working with a limited palette of colors? Is it the current behaviour of paint tools on indexed images? Is it the alpha-thresholding that is done for no good reason? I would really like to know what's important about indexed images so that we can see if there are ways to preserve or even improve that functionality.
David Gowers
2006-08-30 11:19:54 UTC (over 18 years ago)
Henning has already described what he does, and it seems clear to me that alpha-thresholding all paint application would work well for his purposes. I'm sure he'll say if that is not the case.
As for the good of alpha-thresholding, it prevents 'junk' colored pixels that often occur when quantizing quickly to a small palette (solid part of applied paint is colored okay, semitransparent part is colored strangely.. like a bright orange with a medium green) -- cloning a multicolored pattern onto such an image may give you an idea of what I'm talking about. Junk colors are harmful both for mapping (as Henning described) and sprites (where the total amount of pixels is small enough that a single discolored pixel is a significant glitch, and makes it look even worse when palette-swapped)
2006-08-30 19:21:50 UTC (over 18 years ago)
We still need a summary of all this for the design of GIMP 3.0. Unless we can agree on a document that describes what kind of "indexed image" support is needed for our target users, there isn't going to be any.
Henning Makholm
2006-08-31 12:32:08 UTC (over 18 years ago)
Scripsit "David Gowers"
It sounds like a good direction, but I'm not sure that it would also be effective against an accidental application of, say, the smudge tool, or ordinary paint tools that accidentally get used in color-changing (rather than paint-applying) drawing modes.
Henning Makholm
2006-08-31 12:34:22 UTC (over 18 years ago)
Could you describe what you find missing in the explanation of my workflow on real-world examples that I have already posted?
As I have already explained, I need to be sure that I don't accidentally stray from a small predetermined number of colors.
Yes and yes.
The important things about indexed images is that they prevent me from accidentally creating pixel content that does not fit the colormap.
Henning Makholm
2006-08-31 12:36:00 UTC (over 18 years ago)
If it's just an implementation detail, I don't care, of course. But I have difficulty imagining how this setup would be easier to code than a single actual layer whose pixel colors are simply constrained to those of the colormap.
2006-08-31 20:45:43 UTC (over 18 years ago)
We need a document explaining this which is not hidden in a mailing-list thread. A document that we can show to a user interface designer and that he/she is able. And we before we do this, we need to discuss here if we actually want such a feature, if it is at all part of our vision for GIMP.
Henning Makholm
2006-09-04 12:22:28 UTC (over 18 years ago)
I'm afraid I am not able to post documents in less hidden places than mailing list threads.
2006-09-04 12:25:01 UTC (over 18 years ago)
Is wiki.gimp.org a less hidden place than mailing threads? :)
Alexandre
2006-09-04 20:37:01 UTC (over 18 years ago)
The point is not where the document is posted. The mailing-list is fine for this, probably even the best place since it should be discussed. The point is that at the end of this discussion, there should be a self-contained document.
2006-09-04 20:40:37 UTC (over 18 years ago)
Definitely. Putting something up on wiki.gimp.org is pretty much equivalent to writing it on a piece of paper and flushing it down the toilet. Noone notices when something is added to the wiki and it is very unlikely that a developer or user interface designer is ever going to read it.
2006-09-04 20:42:37 UTC (over 18 years ago)
What would it take one to finally add link to the wiki to the sidebar at gimp.org?
Alexandre
2006-09-04 21:10:40 UTC (over 18 years ago)
A nice default theme for the wiki and someone who is willing to clean up obsolete stuff and has the permissions to do so.
That's just my opinion, of course :)
HTH, Michael
2006-09-05 07:39:10 UTC (over 18 years ago)
Not much. That's why it was done some months ago. That doesn't change anything about the fact that wiki.gimp.org is ugly, hopelessly unstructured and pretty much unmaintained.
