Compiling problem with Gimp 2.3.9 in FreeBSD 6.1
8 of 8 messages available
Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Haarald Sinihammas 30 Jun 12:57
  Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Haarald Sinihammas 01 Jul 13:05
   Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Haarald Sinihammas 05 Jul 19:09
    Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Tim Mooney 05 Jul 19:47
     Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Haarald Sinihammas 06 Jul 09:22
      Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Tim Mooney 06 Jul 18:21
      Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Sven Neumann 06 Jul 22:15
       Compiling problem with Gimp 2.3.9 in FreeBSD 6.1 Haarald Sinihammas 07 Jul 00:39
Haarald Sinihammas
2006-06-30 12:57:50 UTC (about 19 years ago)
Hello!
Seems like Gimp compiling from original sources in FreeBSD are very tricky. Configuring is only successful, if i use ./configure LDFLAGS=-I/usr/local/lib CFLAGS =-I/usr/local/include CPPFLAGS=-I/usr/local/include (written by memory, sadly don't have in moment access on this machine). Anyway, configure needs linker, compiler and preprocessor parameters. If using BSD make, then compile fails, if i try gmake, little bit things get better. But then i get error (again, can't quote exact message), that SIGBUS is undefined (unreffered?) function, this happens compiling libgimp/gimp.c - line 340, if i memorize correct. Anybody familiar with FreeBSD can suggest some solutions?
Thank You in advance,
Haarald
Haarald Sinihammas
2006-07-01 13:05:10 UTC (about 19 years ago)
Well, now i can post exact info:
Configure command is: ./configure LDFLAGS=-L/usr/local/lib CFLAGS=-I/usr/local/include/ CPPFLAGS=-I/usr/local/include/
if i doing gmake, then i get for last:
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -DXTHREADS -DXUSE_MTSAFE_API -I/usr/local/include/atk-1.0 -I/usr/local/include/cairo -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I/usr/X11R6/include/gtk-2.0 -I/usr/X11R6/lib/gtk-2.0/include -I/usr/X11R6/include/pango-1.0 -I/usr/X11R6/include -I/usr/local/include/freetype2 -I/usr/local/include -I/usr/local/include -DG_LOG_DOMAIN=\"LibGimp\" -D_REENTRANT -I/usr/local/include/glib-2.0-I/usr/local/lib/glib- 2.0/include -I/usr/local/include/ -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -I/usr/local/include/ -Wall -MT gimp.lo -MD -MP -MF .deps/gimp.Tpo -c gimp.c -fPIC -DPIC -o .libs/gimp.o gimp.c: In function `gimp_main':
gimp.c:340: error: `SIGBUS' undeclared (first use in this function) gimp.c:340: error: (Each undeclared identifier is reported only once gimp.c:340: error: for each function it appears in.) gimp.c:349: error: `SA_RESTART' undeclared (first use in this function) gimp.c: In function `gimp_extension_process': gimp.c:1335: error: syntax error before "readfds" gimp.c:1349: warning: implicit declaration of function `FD_ZERO' gimp.c:1349: error: `readfds' undeclared (first use in this function) gimp.c:1350: warning: implicit declaration of function `FD_SET' gimp.c:1352: warning: implicit declaration of function `select' gimp.c:1352: error: `FD_SETSIZE' undeclared (first use in this function) gimp.c: In function `gimp_plugin_sigfatal_handler': gimp.c:1475: error: `SIGBUS' undeclared (first use in this function) gmake[2]: *** [gimp.lo] Error 1
gmake[2]: Leaving directory `/usr/home/zwoz/Desktop/Downloads/gimp-2.3.9 /libgimp'
gmake[1]: *** [all-recursive] Error 1 gmake[1]: Leaving directory `/usr/home/zwoz/Desktop/Downloads/gimp-2.3.9' gmake: *** [all] Error 2
With best regards,
Haarald
On 6/30/06, Haarald Sini hammas wrote:
Hello!
Haarald
Haarald Sinihammas
2006-07-05 19:09:03 UTC (about 19 years ago)
Hello again!
I don't find any solution yet. Seems like signal.h is not included - but why?
If anybody need more information or clarification to help in this problem, please tell me.
Thanks in advance,
Haarald
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -DXTHREADS -DXUSE_MTSAFE_API -I/usr/local/include/atk- 1.0 -I/usr/local/include/cairo -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I/usr/X11R6/include/gtk-2.0 -I/usr/X11R6/lib/gtk-2.0/include -I/usr/X11R6/include/pango-1.0 -I/usr/X11R6/include -I/usr/local/include/freetype2 -I/usr/local/include -I/usr/local/include -DG_LOG_DOMAIN=\"LibGimp\" -D_REENTRANT -I/usr/local/include/glib- 2.0-I/usr/local/lib/glib- 2.0/include -I/usr/local/include/ -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -I/usr/local/include/ -Wall -MT gimp.lo -MD -MP -MF .deps/gimp.Tpo -c gimp.c -fPIC -DPIC -o .libs/gimp.o gimp.c: In function `gimp_main':
gimp.c:340: error: `SIGBUS' undeclared (first use in this function) gimp.c:340: error: (Each undeclared identifier is reported only once gimp.c:340: error: for each function it appears in.) gimp.c:349: error: `SA_RESTART' undeclared (first use in this function) gimp.c: In function `gimp_extension_process': gimp.c:1335: error: syntax error before "readfds" gimp.c:1349: warning: implicit declaration of function `FD_ZERO' gimp.c:1349: error: `readfds' undeclared (first use in this function) gimp.c:1350: warning: implicit declaration of function `FD_SET' gimp.c:1352: warning: implicit declaration of function `select' gimp.c:1352: error: `FD_SETSIZE' undeclared (first use in this function) gimp.c: In function `gimp_plugin_sigfatal_handler': gimp.c:1475: error: `SIGBUS' undeclared (first use in this function) gmake[2]: *** [ gimp.lo] Error 1
Tim Mooney
2006-07-05 19:47:29 UTC (about 19 years ago)
In regard to: [Gimp-developer] Re: Compiling problem with Gimp 2.3.9 in...:
I tried to respond earlier, but got a bounce.
See
http://bugzilla.gnome.org/show_bug.cgi?id=344203
It's marked as fixed in CVS.
Tim
Haarald Sinihammas
2006-07-06 09:22:30 UTC (about 19 years ago)
Hello!
After last night and today "hacking" i now stuck again. If i update from cvs original gimp-2.3.9 (thank you for help, Tim :)), then anyway this don't work (cvs refuse update some files). If i get full source from cvs then i have trouble with autogen.sh - okay, lets using aclocal19 and so on.
But if i run automake19 -a, then i got:
configure.in:67: required file `config.h.in' not found
What program must make this config.h.in or how i get it? Maybe somebody can post working configure script for cvs source?
With best regards and thanks anybody in advance,
Haarald
On 7/5/06, Tim Mooney wrote:
In regard to: [Gimp-developer] Re: Compiling problem with Gimp 2.3.9in...:
-MT
.libs/gimp.o
See
Tim --
Tim Mooney mooney@dogbert.cc.ndsu.NoDak.edu Information Technology Services (701) 231-1076 (Voice) Room 242-J6, IACC Building (701) 231-8541 (Fax) North Dakota State University, Fargo, ND 58105-5164
Tim Mooney
2006-07-06 18:21:47 UTC (about 19 years ago)
In regard to: Re: [Gimp-developer] Re: Compiling problem with Gimp 2.3.9 in...:
Hello!
I'm not sure why this is happening for you, but if you're having trouble with CVS, perhaps you should try the 2.3.10 development snapshot?
Tim
2006-07-06 22:15:54 UTC (about 19 years ago)
You should use autogen.sh. If you want to specify a particular binary to use instead of aclocal, you can do that by setting the appropriate environment variables:
ACLOCAL=aclocal19 ./autogen.sh
Haarald Sinihammas
2006-07-07 00:39:42 UTC (about 19 years ago)
Hello!
Many thanks for answers!
Maybe some day i try cvs source compiling again. Now i have successfully compiled working gimp from devel release - 2.3.10 are nice. Thanks, Tim, i think i should read more announcements :)
With best regards, Haarald
