Gimp python
11 of 11 messages available
Gimp python Joao S. O. Bueno Calligaris 28 Jun 06:20
  Gimp python Sven Neumann 28 Jun 08:41
   Gimp python Sven Neumann 14 Aug 21:17
    Gimp python Joao S. O. Bueno Calligaris 15 Aug 04:34
    Gimp python Sven Neumann 31 Aug 09:32
     Gimp python Sven Neumann 13 Sep 10:31
      Gimp python Sven Neumann 17 Sep 15:51
       Gimp python Sven Neumann 22 Sep 00:16
        Gimp python Sven Neumann 05 Oct 08:24
         Gimp python Alexandre Prokoudine 05 Oct 09:36
          Gimp python Sven Neumann 05 Oct 20:26
2006-06-28 06:20:55 UTC (over 19 years ago)
Gimp python
In bug #346001, Sven wrote:
Comment #3 from sven@gimp.org (GIMP developer, points: 23) 2006-06-27 13:47 UTC [reply]
If you ask me, Python-Fu must not install any plug-ins at all as long as the user interface doesn't hold up to our standards. This includes complete internationalization and localization. I suggest that we disable installation of Python plug-ins for the 2.4 release.
(http://bugzilla.gnome.org/show_bug.cgi?id=346001)
I consider this both sad and grave. IMHO, the build of python-fu by default, and support for it under Redmond OS is one of the greatest things in this development cycle.
I will undertake i18n of the python-fu then, with no delays. What else do you consider important for the UI to have for it to keep up with gimp standards?
JS ->
2006-06-28 08:41:56 UTC (over 19 years ago)
Gimp python
Huh? I never suggested that the build of Python-Fu should be disabled or anything like that. I am only suggesting that it doesn't install any of its example plug-ins that don't serve any particular purpose but being examples for plug-in authors. Such plug-ins can very well be in the source tree, but they must not show up in the menus.
It's a bit late now to add another translation domain. I think this should wait for 2.6.
What else
Have a look at one of the Python-Fu dialog windows. Any further questions?
2006-08-14 21:17:22 UTC (about 19 years ago)
Gimp python
I have opened a bug report on what I believe to be the remaining issues with gimp-python:
http://bugzilla.gnome.org/show_bug.cgi?id=351287
Even though I said earlier that's it's perhaps too late for adding i18n support, I feel now that we absolutely need to do this if we want to install any Python plug-ins by default.
But still, if i18n support is added, the usefulness of the plug-ins should be reviewed and only the plug-ins that are considered useful should be installed and have their strings marked for translation (and reviewed).
2006-08-15 04:34:07 UTC (about 19 years ago)
Gimp python
Hi Sven -
thank you for getting to this.
I am rather busy these days, but I will dig into it as soon as I have some time to the GIMP. I that is too late to 2.4 - well, thats is life.
And in fact, even very simple scripts can be more usefull than the ones that ship by default, and at once be so simple taht could encourage more people to give a try at editing then. (center layer, apply a filter varying its parameters in a sequence o vertical slices of an image, and so on).
Lets see what we all can come up with.
JS ->
2006-08-31 09:32:32 UTC (about 19 years ago)
Gimp python
Moin,
Regarding http://bugzilla.gnome.org/show_bug.cgi?id=351287 some progress has been made in CVS. To avoid i18n problems, the procedure registration in pygimp has been changed (in a hopefully backwards compatible way). It shouldn't be too difficult to add i18n now. But still, there hasn't been any further progress on this. We urgently need this to happen so that we can enter string freeze. Any volunteers?
2006-09-13 10:31:45 UTC (about 19 years ago)
Gimp python
the internationalisation of the Gimp Python bindings and plug-ins is still pending:
Does this mean that noone is interested in having the existing Python scripts in GIMP 2.4? It should not be difficult to make the plug-ins use the existing gettext module for Python (http://docs.python.org/lib/module-gettext.html) and that's basically all that needs to be done.
Perhaps someone can look over the strings in the meantime and make sure that there are no typos or other errors?
2006-09-17 15:51:06 UTC (about 19 years ago)
Gimp python
We have come a good deal further here in the meantime. The framework for internationalisation is now in place. What's missing is the review of the strings (basically the same job as what's needed for Script-Fu, only much fewer strings) and marking them for translation. Any volunteer who wants to go over the python plug-ins, check that the strings are OK and that the procedure blurbs have the same style as what is used by the plug-ins? The files to look at are (from the plug-ins/pygimp/plug-ins folder):
clothify.py
colorxhtml.py
foggify.py
happy-valley-relief.py
palette-offset.py
palette-sort.py
palette-to-gradient.py
pdbbrowse.py
py-slice.py
shadow_bevel.py
This list does intentionally leave out plug-ins that are already internationalized or are not installed in a stable release and are only included as examples.
2006-09-22 00:16:25 UTC (about 19 years ago)
Gimp python
In the meantime, while Carol is trying to steal your time with pointless mails, the Python i18n effort is basically done. It would be nice if someone could review the strings that have been marked for translation. I would like to point translators to the new set of translatable messages soon and they would probably appreciate if the strings would not have to be changed before 2.4.
2006-10-05 08:24:20 UTC (about 19 years ago)
Gimp python
Should we consider the messages as fine then?
2006-10-05 09:36:47 UTC (about 19 years ago)
Gimp python
Does reviewing mean that someone goes through scripts, marks forgotten messages and err... unmarks those that should not be translated?
Alexandre
2006-10-05 20:26:04 UTC (about 19 years ago)
Gimp python
Sure, I might have forgotten a message or two. But the main point of such a review is that someone else, preferably a native speaker, looks over the messages and checks them for spelling and grammatical errors. The easiest way to do this is by looking at the gimp20.pot file in the po-python directory.
