[Gmip-developer] Editable Polygon
[Gmip-developer] Editable Polygon sampin 21 Jun 03:13
sampin
2006-06-21 03:13:26 UTC (almost 19 years ago)
I'm working on an interactive image cutout plug in. After the first cutout the boundaries should be adjusted by the user. For this purpose an editable polygon roughly outlines the boundaries. The user then may modify the polygon by moving the vertices or by introducing new vertices. Two vertices are connected through a strait line.
What gimp functions do you recommend using for creating such an editable polygon? gimp_path?
Thank you
Ollie
