gimp-python: checking if point is in selection
gimp-python: checking if point is in selection Sebastian Breuers 02 Jun 13:48
  gimp-python: checking if point is in selection saulgoode@brickfilms.com 02 Jun 19:44
   gimp-python: checking if point is in selection Sebastian Breuers 03 Jun 12:05
  gimp-python: checking if point is in selection Sven Neumann 02 Jun 19:54
   gimp-python: checking if point is in selection Sebastian Breuers 02 Jun 23:16
    gimp-python: checking if point is in selection Michael Natterer 02 Jun 23:30
Sebastian Breuers
2006-06-02 13:48:07 UTC (almost 19 years ago)
Hello@all
i wondered if there is a possibility to check, if a point is in a given selection by using an internal gimp function. If it's not, could someone give me a hint, how to achieve this in creating an own function?
seb
Mail: sebbreuers@gmx.de
2006-06-02 19:44:33 UTC (almost 19 years ago)
Quoting Sebastian Breuers :
I don't use Python-fu but the following Script-fu function should be easily ported (or perhaps you can find a better way):
(define (point-in-selection image x y) (let* (
(saved (car (gimp-selection-save image))) (return-value)
(gimp-rect-select image x y 1 1 CHANNEL-OP-INTERSECT 0 0) (set! return-value (car (gimp-selection-is-empty image))) (gimp-selection-load saved)
(if (= return-value 0)
Note that the selection does not include the points at the rightmost and bottommost edges. For example, if the selection is from (0,0) to (10,10) then the point (10,10) is *not* "in" the selection but (9,9) is. You may need to adjust things to account for this.
2006-06-02 19:54:41 UTC (almost 19 years ago)
Use gimp-image-get-selection to get the selection mask and check the value of the pixel you are interested in.
Sebastian Breuers
2006-06-02 23:16:16 UTC (almost 19 years ago)
Am Freitag, 2. Juni 2006 19:54 schrieben Sie:
Hi, Sven,
i've already found the selection function, but could you tell me how to check the value of the pixel?
seb
Michael Natterer
2006-06-02 23:30:39 UTC (almost 19 years ago)
Hi, Sven,
Use gimp-selection-value
ciao, --mitch
Sebastian Breuers
2006-06-03 12:05:40 UTC (almost 19 years ago)
Am Freitag, 2. Juni 2006 19:44 schrieb saulgoode@brickfilms.com:
Hi.
thanks for the tip. works fine.
seb
