Combine masks & UNDO history
Combine masks & UNDO history saulgoode@brickfilms.com 26 May 11:02
  Combine masks & UNDO history Michael Natterer 26 May 13:51
   Combine masks & UNDO history saulgoode@brickfilms.com 26 May 15:15
2006-05-26 11:02:04 UTC (almost 19 years ago)
I am not sure that this is a bug so I thought I would mention it here.
The PDB function 'gimp-channel-combine-masks' does not appear to register with the UNDO history. Perhaps it is not supposed to since it does not modify the image but there are some other functions that don't modify the image (that affect channels, paths, and selections) that do get added to the UNDO history.
I can't think of any practical difficulties that might arise from this; I only encountered it while debugging a script-fu. Nonetheless, it would seem to me that this function should be UNDO-able but then I do not really know what the criteria for the UNDO-ability of a functions is.
To demonstrate:
;; select a rectangular region (set! rect (car (gimp-selection-save image))) ;; select a elliptical region
(set! circle (car (gimp-selection-save image))) (gimp-channel-combine-masks rect circle CHANNEL-OP-INTERSECT 0 0 )
;; The operation is not UNDOable (should it be?)
Michael Natterer
2006-05-26 13:51:46 UTC (almost 19 years ago)
Of course it modifies the image. The saved channel is part of the image. Please file a bug about this.
What functions are these exactly? Everything that changes the image must be undoable, and channels, selections and paths *are* part of the image. Any exception needs a very good reason and must be documented.
Please file bugs for these functions too.
ciao, --Mitch
2006-05-26 15:15:25 UTC (almost 19 years ago)
Quoting Michael Natterer :
Thank you for the explanation. I was obviously confused.
http://bugzilla.gnome.org/show_bug.cgi?id=343026
I now realize that the functions that *do* get added ("gimp-selection-none", being a simple example) are, in actuality, modifying the image. My confusion stemmed from a comment that the "gimp-edit-copy-visible" was not added to the UNDO history because it didn't modify the image. I inferred more from this comment than I should have.
