[PATCH] Code fixes for -ansi -pedantic build
[PATCH] Code fixes for -ansi -pedantic build Daniel Richard G. 20 May 07:59
Daniel Richard G.
2006-05-20 07:59:04 UTC (almost 19 years ago)
I usually build with -ansi -pedantic in my CFLAGS, to prevent silly non-portable-isms from slipping into my code. As it happens, GIMP CVS has a few of these, but they are easily addressed and I have submitted a patch to that effect:
http://bugzilla.gnome.org/show_bug.cgi?id=342390
The most worrisome bits are in four (now three) particular plug-ins, where you have non-static, non-extern variables being defined in common header files---leading, of course, to the linker bombing out on multiply-defined symbols.
--Daniel
