about lanczos
2 of 4 messages available
3495b4ac0605102151l62348ffo... 07 Oct 20:24
  about lanczos Roberto Winter 11 May 06:55
   about lanczos Alastair M. Robinson 11 May 13:06
3495b4ac0603272221x54b872a1... 07 Oct 20:24
Roberto Winter
2006-05-11 06:55:21 UTC (about 19 years ago)
about lanczos
I wrote the following a long time ago, I got a bounce from the list because the attachment was over 40Kb.
Re-read it and I am now sending it again. Attached a smaller file this time...
I guess the whole point is that Lanczos is not really the 'best' algorithm for reducing images (as suggested in the scalings dialogs whe selecting the algorithm). Now, isn't there a problem?...
--------------- Hello!
I am currently using gimp from cvs. I couldn't help to notice that the new Lanczos algorithm is available when resizing images. I also noticed that it is marked as "Best".
But my tests show something else, see the attached image I created an image with inkscape that was about 800px wide and then resized it to a third using two methods (Lanczos and Cubic). Then I resized that again so that I could see what was already clear: Lanczos is not better than Cubic!!!
Am I missing something?
Roberto
2006-05-11 13:06:17 UTC (about 19 years ago)
about lanczos
Yes, there is - and the problem isn't just that Lanczos is not the "best" algorithm for reducing images, *interpolation* of any kind is inapproprite when reducing images.
Interpolation allows us to estimate pixel values that "fall in the cracks" between sample points in the original image - which is a great help when enlarging; however, when reducing, the "correct" approach is to perform a weighted average of all source pixels that are "covered" by the destination pixel.
Cubic interpolation gives a tolerable approximation of the "correct" method; Lanczos Sinc, it would appear, doesn't.
Another point worth considering is that, while for band-limited photographic images Lanczos performs very well, for artifically sharp images it can result in almost JPEG-like ringing artifacts.
So while it produces the "best" results for many images - and is certainly the method that causes the least amount of blurring when rotating an image by a few degrees, it's not *always* the best choice.
All the best, --
