One layer merges
One layer merges saulgoode@brickfilms.com 02 May 05:54
  One layer merges Sven Neumann 02 May 09:19
2006-05-02 05:54:02 UTC (almost 19 years ago)
One layer merges
Rather than have a merge of a single visible layer result in an error message, would it be preferable to have the operation apply the Opacity setting to the layer?
ADVANTAGES:
* Eliminates an error message pop-up. * More intuitive. Merging down first applies the Opacity and then combines the layers. This method would retain the first step. * Eliminate the need to create a new transparent layer and merge that to apply the opacity. (At least, that's how I accomplish this.) * _Shouldn't_ affect plugins. I wouldn't think a plugin programmer would depend upon the GIMP core to control error interfaces with the user.
DISADVANTAGES:
* Eliminates a "stupidity check" for the user. (I prefer to assume a user knows what he is doing.)
* _Might_ impact other parts of the GIMP. Perhaps this would have an affect on things such as exporting; which is why I am asking.
I would be willing to pursue implementing this change if it is deemed desirable.
2006-05-02 09:19:01 UTC (almost 19 years ago)
One layer merges
saulgoode@brickfilms.com writes:
Perhaps not a bad idea at all. Can you file a bug report for this and perhaps attach a patch against current CVS (or 2.3.8)?
