stdout from lisp
stdout from lisp saulgoode@brickfilms.com 09 Apr 18:34
  stdout from lisp Kovacs Baldvin 10 Apr 14:29
  stdout from lisp Kevin Cozens 10 Apr 18:30
2006-04-09 18:34:44 UTC (about 19 years ago)
stdout from lisp
Kovacs,
Output from Script-fu can be sent to "stdout" by first performing a:
(gimp-message-set-handler 1)
and then sending your strings using something like
(gimp-message "foobar")
where "foobar" is the string to printed on "stdout".
Perhaps this will be sufficient for your needs?
Kovacs Baldvin
2006-04-10 14:29:12 UTC (about 19 years ago)
stdout from lisp
On Sun, Apr 09, 2006 at 09:34 -0700, saulgoode@brickfilms.com wrote:
Kovacs,
Yes, definitely! Thank you very much!
(P.s.: as a "keep it stupid and simple" fan I'd probably arrange things in a way that the default print methods of siod do print to stdout. But anyways, what I really needed is just any method to print, so I'll do with what you showed.).
Thanks, Baldvin
Kevin Cozens
2006-04-10 18:30:28 UTC (about 19 years ago)
stdout from lisp
The Procedure Browser shows that the arguments '1' has an equivalent (C style) name of GIMP_CONSOLE. In Script-Fu you remove the leading GIMP_ from named constants shown in the Procedure Browser and change any remaining _ to -. That would mean you could use
(gimp-message-set-handler CONSOLE)
which has the extra benefit of being more readable. You don't have to go back to the procedure browser to find out what the 1 means.
Just a suggestion to use the named constants where available to make the scripts a little more readable, save some trips back to the procedure browser which should make any needed debugging a little less tedious.
