Smaller toolbar and grouping
Smaller toolbar and grouping Bart 01 Apr 17:32
  Smaller toolbar and grouping Jon A. Cruz 01 Apr 20:51
   Smaller toolbar and grouping Campbell Barton 01 Apr 21:08
   Smaller toolbar and grouping Bart 01 Apr 23:54
    Smaller toolbar and grouping Campbell Barton 03 Apr 18:51
Bart
2006-04-01 17:32:33 UTC (about 19 years ago)
just a proposal about a smaller toolbar and a way grouping of buttons in the toolbar (not about what kind of buttons belong to which specific group and there position etc.).
http://www.neeneenee.de/blender/toolbar.png
Jon A. Cruz
2006-04-01 20:51:15 UTC (about 19 years ago)
That seems pretty....
However, from a usability standpoint it might be much harder to use than just a straight line of buttons popping up either below or to the right. (Similar to the "don't have to stop and look for it" position for the Mac OS menubar on the screen not the window).
There could be an argument for it becoming second nature, like Graffiti moves on a Palm, but then you also have to commit to keeping the popups' relative locations in the same spots forever.
Also, while some people work more naturally with mouse gestures, others do not.
Campbell Barton
2006-04-01 21:08:38 UTC (about 19 years ago)
Hey Bart.. Another Blender3D person here!
As far as useability, goes- im that That fussed. though I tend towards the more common row of buttons under the button your pressing (alligned to the right/left)
This is simple because your not limited to a 4 options. (okay 5 would work but look silly) and since a diagonal button is not a part of the options but still outlined somewhat, (in barts example the measurement tool is outlined on 3 sides, though I can tell its not an option, a quick click and select may be more confusing in this case.) its better to just have a row//
Another resion to use a left/right aligned row. is that many people place there toolbars at the side of there screen. no5. would have the LHS button off the screen.
Still I like the idea of having nested buttons, especialy for the transform tools that I rarely use but need to access. - Cam
Bart
2006-04-01 23:54:54 UTC (about 19 years ago)
thanks for the replies, so i going on with it: http://www.neeneenee.de/blender/toolbar02.png
Campbell Barton
2006-04-03 18:51:14 UTC (about 19 years ago)
Nice work Bart, even though I was against it- good on you for exploring the radial approach.
Can GTK do this at the moment?
it seems desirable (prever hoz buttons) and if gtk supports, Im guessing its not that bug a deal.
- Cam
