Gimp-Python with no ui? (external script)
13 of 13 messages available
Gimp-Python with no ui? (external script) Ministeyr 30 Mar 15:31
  Gimp-Python with no ui? (external script) Carol Spears 30 Mar 17:10
   Gimp-Python with no ui? (external script) Ministeyr 30 Mar 20:02
    Gimp-Python with no ui? (external script) Carol Spears 30 Mar 20:09
     Gimp-Python with no ui? (external script) Ministeyr 01 Apr 15:01
      Gimp-Python with no ui? (external script) Carol Spears 01 Apr 16:49
  Gimp-Python with no ui? (external script) Manish Singh 30 Mar 19:36
   Gimp-Python with no ui? (external script) Ministeyr 30 Mar 19:59
    Gimp-Python with no ui? (external script) Manish Singh 30 Mar 20:00
     Gimp-Python with no ui? (external script) Ministeyr 01 Apr 14:58
      Gimp-Python with no ui? (external script) Manish Singh 02 Apr 01:00
Gimp-Python with no ui? (external script) Alex Borghgraef 05 Apr 13:30
Gimp-Python with no ui? (external script) Alex Borghgraef 12 Apr 16:33
Ministeyr
2006-03-30 15:31:12 UTC (over 19 years ago)
I need to make an external Python administration script, wich occasionnally uses gimp functionnality (especially to convert to/from xcf files). Is there a way to use this functionnality without starting the ui?
I need something like that:
import gimp_noui as gimp gimp.startgimp() #start the gimp in background process pdb.file_load(whatever...)
#do something here...
pdb.file_save(whatever...)
gimp.stopgimp()
Thanks.
Carol Spears
2006-03-30 17:10:48 UTC (over 19 years ago)
gimp.stopgimp()
Thanks.
what os will you be using this on?
Manish Singh
2006-03-30 19:36:17 UTC (over 19 years ago)
gimp.stopgimp()
Just write a pygimp script normally, and call it via gimp's batch mode.
-Yosh
Ministeyr
2006-03-30 19:59:08 UTC (over 19 years ago)
-Yosh
I would prefer another solution, since I have some processing to do in the external script and possibly a bunch of data to transfer back and forth, so it would make the script quite complex to have to use the batch interpreter.
By the way, I thought the batch mode only understood scheme, so it would make the whole thing even more complicated. I hope there is a simpler solution possible.
Ministeyr
Manish Singh
2006-03-30 20:00:50 UTC (over 19 years ago)
-Yosh
Why would it?
One line of scheme to call your python script won't increase the complexity appreciably.
Well, it's kind of hacky yes, but it's not *complex*.
If you want something better, why don't you contribute it?
-Yosh
Ministeyr
2006-03-30 20:02:51 UTC (over 19 years ago)
I'm developping it for and under a Debian-testing system (on amd k7), and plan to use it possibly also on an Ubuntu Linux. I won't need windows support.
Ministeyr
Carol Spears
2006-03-30 20:09:08 UTC (over 19 years ago)
i asked because i put instructions of how to do this online.
i have a crontab that runs gimp.
that being said, it has been running for so long now, i have no idea what sort of mess it is making, but it was all so easy that it was a pleasure to put the instructions online.
Ministeyr
2006-04-01 14:58:12 UTC (over 19 years ago)
Manish Singh wrote:
>> By the way, I thought the batch mode only understood scheme, so it would make the whole thing even more complicated. >
> One line of scheme to call your python script won't increase the > complexity appreciably.
The problem is that if i have huge lists and complex python objects in my external scripts, and i want to access them in the gimp's python-fu script, i have to pass them through scheme, and thus it means converting back and forth.
I will try to adapt with pickle if it works.
I would make a mess, since i'm not really a good programmer (plus i don't know anything about gimp's internal structure or python's...).
Ministeyr
Ministeyr
2006-04-01 15:01:31 UTC (over 19 years ago)
Well, i don't know if that is exactly what i meant, but i would still be grateful if you could give me the url to that document. Thanks.
Ministeyr
Carol Spears
2006-04-01 16:49:59 UTC (over 19 years ago)
http://carol.gimp.org/gimp/scripting/routines.html#shell
Manish Singh
2006-04-02 01:00:07 UTC (over 19 years ago)
You could serialize them to a temporary file, or choose from a number of IPC methods python ships with. No need to pass stuff like that over the command line.
How were you planning on doing it via your original though of having having a "gimp_noui" anyway? The issues are more or less the same.
-Yosh
Alex Borghgraef
2006-04-05 13:30:50 UTC (over 19 years ago)
Carol Spears gimp.org> writes:
Does that work with gimp 2.2? I'm also trying to get a pygimp script to run in batch mode, but it doesn't work. I tried running your python_fu_batch_resize example (adapting directories of course) but it didn't work. So I wrote a simple test script and I tried running that. This is the code:
#!/usr/bin/python
from gimpfu import *
def test(): width = 530
height= 56
bg_colour = (255, 255, 255)
# Create new image
img = pdb.gimp_image_new(width, height, RGB)
# Create and fill background layer bg_layer = pdb.gimp_layer_new(img, width, height, RGBA_IMAGE, "Background", 100, NORMAL_MODE)
pdb.gimp_context_set_background(bg_colour) pdb.gimp_drawable_fill(bg_layer,BACKGROUND_FILL) pdb.gimp_image_add_layer(img,bg_layer,0) pdb.gimp_display_new(img)
register("Test",
"/Xtns/Python-Fu/Test",
"RGB*, GRAY*",
test
main()
I called gimp like this
gimp-2.2 -i -b '(Test RUN-NONINTERACTIVE)' -b '(gimp-quit 0)'
And I got these messages:
No batch interpreter specified, using the default 'plug_in_script_fu_eval'. batch command: experienced an execution error. batch command: experienced an execution error.
The script works normally when called from within gimp, so I don't really see why it should fail, unless gimp doesn't process python in batch mode. What am I doing wrong here?
Alex
Alex Borghgraef
2006-04-12 16:33:22 UTC (about 19 years ago)
Alex Borghgraef gmail.com> writes:
Ok, I found the problem: the plugin is registered under the name "Test", which works under gimp, but not in batch mode, which requires "python-fu-Test". Weird thing is that even if I keep "Test" as name in the register call, a call in batch mode to "python-fu-Test" will work.
-- Alex
