crash after saving tif
crash after saving tif Roberto Winter 25 Mar 05:19
  crash after saving tif Tim Jedlicka 25 Mar 05:49
  crash after saving tif Michael Natterer 25 Mar 13:32
   crash after saving tif Roberto Winter 26 Mar 03:51
  crash after saving tif Kai-Uwe Behrmann 26 Mar 13:03
   crash after saving tif Roberto Winter 27 Mar 06:38
Roberto Winter
2006-03-25 05:19:58 UTC (about 19 years ago)
hi.
as i saved a file just now gimp crashed. i had it built from cvs some 10 days ago (gcc 3.3.5).
i'm using debian unstable, e16 window manager, nvidia drivers 8178 on xorg and kernel 2.6.13.1 .
on the terminal i got:
file_save_dialog_check_uri: URI = file:///home/media/fotos_tangara/xcf/tif/IMG_6384.TIF
file_save_dialog_check_uri: basename = IMG_6384.TIF file_save_dialog_check_uri: selected save_proc: NULL file_save_dialog_check_uri: URI save_proc: TIFF image file_save_dialog_check_uri: basename save_proc: TIFF image
file_save_dialog_check_uri: no save_proc was selected from the list file_save_dialog_check_uri: use URI's proc 'TIFF image' so indirect saving works
*** glibc detected *** corrupted double-linked list: 0x0a86a390 *** /opt/gimp/bin/gimp-2.3: terminated: Aborted
(script-fu:4033): LibGimpBase-WARNING **: script-fu: wire_read(): error
the image is a 8Mp photograph. it was a single layer file.
is this known? should i report a bug (i suspect it might be something with my environment, not gimp)? has it been noticed? fixed? the thing is it had been running absolutely stable the last days. and the weirder is that it crashed while doing something that i do often (saving as tif).
another thing that might matter is that the file was written fine and is not corrupted (~10Mb in size).
thanks for any help, roberto
Tim Jedlicka
2006-03-25 05:49:26 UTC (about 19 years ago)
Don't know if this is your problem but I saw something similiar a long while back. Turned out I ran out of swap space. Confirm that your swap is functioning (via "top" or various other methods).
Michael Natterer
2006-03-25 13:32:41 UTC (about 19 years ago)
On Sat, 2006-03-25 at 01:19 -0300, Roberto Winter wrote:
hi.
i'm using debian unstable, e16 window manager, nvidia drivers 8178 on xorg and kernel 2.6.13.1.
file_save_dialog_check_uri: URI = file:///home/media/fotos_tangara/xcf/tif/IMG_6384.TIF file_save_dialog_check_uri: basename = IMG_6384.TIF file_save_dialog_check_uri: selected save_proc: NULL file_save_dialog_check_uri: URI save_proc: TIFF image file_save_dialog_check_uri: basename save_proc: TIFF image
I've seen crashes with exactly this glibc warning with a lot of different apps recently on sid, and after yesterday's update they didn't occur again.
IMHO this is not a gimp problem.
ciao, --mitch
Roberto Winter
2006-03-26 03:51:32 UTC (about 19 years ago)
hi.
I guess you are right.
ciao,
--mitch
Kai-Uwe Behrmann
2006-03-26 13:03:04 UTC (about 19 years ago)
Similiar problems where reported for CinePaint. Look at your libtiff version. If it has 3.8.0 update or downgrad. This libtiff version is buggy.
Hopd this helps.
kind regards Kai-Uwe Behrmann
+ development for color management + imaging / panoramas + email: ku.b@gmx.de + http://www.behrmann.name
Am 25.03.06, 01:19 -0300 schrieb Roberto Winter:
hi.
Roberto Winter
2006-03-27 06:38:12 UTC (about 19 years ago)
$ apt-cache policy libtiff4
libtiff4:
Installed: 3.8.0-3
Candidate: 3.8.0-3
Version Table:
*** 3.8.0-3 0
500 http://ftp.uk.debian.org unstable/main Packages 500 http://ftp.fr.debian.org unstable/main Packages 100 /var/lib/dpkg/status
buggy.
really?
mmm... good to know!
Hopd this helps.
kind regards
Kai-Uwe Behrmann
hi.
xorg
saving
works
with
the
as
tif).
not
