Problem with gimp-cvs and gimp stable configs
Problem with gimp-cvs and gimp stable configs Frédéric 24 Mar 15:22
  Problem with gimp-cvs and gimp stable configs Sven Neumann 25 Mar 23:34
   Problem with gimp-cvs and gimp stable configs Frédéric 26 Mar 10:29
Frédéric
2006-03-24 15:22:45 UTC (almost 19 years ago)
I recently compiled gimp from 2.3.7 tarball, and then from CVS, to test the new features. This version is installed in /usr/local, and uses ~/.gimp-2.3 config dir (which was generated from ~/.gimp-2.2 the first time I launched gimp-2.3, if I remember).
Yesterday, I tried to launch the stable version (from debian etch package), but it failed with a seg. fault. The problem seems to be the config dir used: the stable version (2.2.10) loads configs from the ~/.gimp-2.3, not from ~/.gimp-2.2. And if I remove ~/.gimp-2.3, Gimp launchs the configuration wizard.
I tried to reinstall all gimp packages from debian repository, without success.
Any idea ?
Thanks,
2006-03-25 23:34:01 UTC (almost 19 years ago)
Frédéric writes:
You ignored the warning in the release notes that ask you to install the development version in a separate prefix that is not part of the system library search path. Or perhaps the release notes need to be improved to make it more clear that gimp-2.2 will start to use the gimp-2.3 libraries if these are installed in /usr/local/lib and /usr/local/lib is in the library search path before /usr/lib.
Frédéric
2006-03-26 10:29:14 UTC (almost 19 years ago)
Ok, I see. You are right, I thought that /usr/local was OK. I uninstalled gimp-2.3 from /usr/local, and gimp-2.2 is running again.
I will re-run autogen.sh with an other --prefix path.
Thanks,
