building from cvs
building from cvs Roberto Winter 06 Mar 04:37
building from cvs William Skaggs 06 Mar 16:51
  building from cvs Roberto Winter 07 Mar 06:21
  building from cvs Sven Neumann 07 Mar 08:40
Roberto Winter
2006-03-06 04:37:45 UTC (over 19 years ago)
building from cvs
hello to all,
tried to build the cvs gimp on debian unstable and got this:
gcc -g -O2 -Wall -o .libs/gimp-2.3 app_procs.o main.o batch.o errors.o sanity.o units.o gui/libappgui.a actions/libappactions.a dialogs/libappdialogs.a menus/libappmenus.a display/libappdisplay.a tools/libapptools.a widgets/libappwidgets.a pdb/libapppdb.a vectors/libappvectors.a plug-in/libappplug-in.a core/libappcore.a paint/libapppaint.a xcf/libappxcf.a text/libapptext.a file/libappfile.a config/libappconfig.a
paint-funcs/libapppaint-funcs.acomposite/libappcomposite.a base/libappbase.a
../libgimpwidgets/.libs/libgimpwidgets-2.0.so../libgimpmodule/.libs/libgimpmodule- 2.0.so ../libgimpcolor/.libs/libgimpcolor-2.0.so../libgimpthumb/.libs/libgimpthumb- 2.0.so ../libgimpmath/.libs/libgimpmath-2.0.so../libgimpconfig/.libs/libgimpconfig- 2.0.so ../libgimpbase/.libs/libgimpbase-2.0.so -L/usr/X11R6/lib /usr/lib/libgtk-x11-2.0.so /usr/lib/libgdk-x11-2.0.so -lXrandr -lXi -lXinerama -lXext /usr/lib/libatk-1.0.so /usr/lib/libgdk_pixbuf-2.0.so -lm /usr/lib/libpangocairo-1.0.so /usr/lib/libXcursor.so /usr/lib/libcairo.so /usr/lib/libXrender.so -lX11 /usr/lib/libart_lgpl_2.so /usr/lib/libpangoft2- 1.0.so /usr/lib/libpango-1.0.so /usr/lib/libgobject-2.0.so/usr/lib/libgmodule- 2.0.so -ldl -lfontconfig /usr/lib/libfreetype.so -lz -pthread /usr/lib/libgthread-2.0.so /usr/lib/libglib-2.0.so -Wl,--rpath -Wl,/opt/gimp/lib
gui/libappgui.a(gui.o)(.text+0x9cb): In function `gui_restore_callback': /home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui.c:396: undefined reference to `actions_init'
gui/libappgui.a(gui.o)(.text+0x9d3):/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui.c:397: undefined reference to `global_action_factory' gui/libappgui.a(gui.o)(.text+0xdd1): In function `gui_exit_after_callback': /home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui.c:520: undefined reference to `actions_exit'
gui/libappgui.a(gui.o)(.text+0xb9d): In function `gui_restore_after_callback':
/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui.c:452: undefined reference to `dialogs_show_toolbox'
gui/libappgui.a(gui.o)(.text+0x1085): In function `gui_image_disconnect': /home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui.c:638: undefined reference to `dialogs_show_toolbox'
gui/libappgui.a(gui-vtable.o)(.text+0x8c2): In function `gui_menus_create_item':
/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui-vtable.c:503: undefined reference to `plug_in_actions_add_path' gui/libappgui.a(gui-vtable.o
)(.text+0x91e):/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui- vtable.c:499: undefined reference to `plug_in_actions_add_proc' gui/libappgui.a(gui-vtable.o)(.text+0x98a): In function `gui_menus_delete_item':
/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui-vtable.c:531: undefined reference to `plug_in_actions_remove_proc' gui/libappgui.a(gui-vtable.o)(.text+0x9e5): In function `gui_menus_create_branch':
/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/gui/gui-vtable.c:547: undefined reference to `plug_in_actions_add_branch' tools/libapptools.a(gimpvectortool.o)(.text+0x2c1a): In function `gimp_vector_tool_stroke_vectors':
/home/rhwinter/docs/programacao/gimp/cvs/gimp/app/tools/gimpvectortool.c:1897: undefined reference to `stroke_dialog_new' collect2: ld returned 1 exit status
make[3]: ** [gimp-2.3] Erro 1
make[3]: Leaving directory
`/home/rhwinter/docs/programacao/gimp/cvs/gimp/app' make[2]: ** [all-recursive] Erro 1
make[2]: Leaving directory
`/home/rhwinter/docs/programacao/gimp/cvs/gimp/app' make[1]: ** [all-recursive] Erro 1
make[1]: Leaving directory `/home/rhwinter/docs/programacao/gimp/cvs/gimp' make: ** [all] Erro 2
can anyone help me with this?
thanks a lot in advance, roberto
William Skaggs
2006-03-06 16:51:18 UTC (over 19 years ago)
building from cvs
Please file a Bugzilla report about this. There are several possible explanations, and it would be good to be able to deal with them in a more systematic way than this mailing list.
Also, in your bug report, it would be helpful for you to tell us what verions of gcc you are using, and what kind of hardware you are running on.
Thanks, -- Bill
Roberto Winter
2006-03-07 06:21:49 UTC (over 19 years ago)
building from cvs
mmm...
I updated earlier today from cvs and tried to build again. all went smoothly this time.
thanks anyway.
roberto
Thanks, -- Bill
2006-03-07 08:40:27 UTC (over 19 years ago)
building from cvs
"William Skaggs" writes:
It is more than appropriate to ask on the mailing-list in such a case. The likelihood that this is a bug is very small. It is most likely just a problem with either the CVS checkout or the build environment. Having bug reports for such problems would be rather annoying. Our bug-tracker is not a help forum. Please don't encourage people to use it as such.
