[SCM] text file management
[SCM] text file management Fab Psycho 09 Jan 20:45
  [SCM] text file management Nathan Summers 10 Jan 18:15
  [SCM] text file management Sven Neumann 10 Jan 21:57
   [SCM] text file management Nathan Summers 11 Jan 16:25
    [SCM] text file management Simon Budig 11 Jan 17:36
     [SCM] text file management Nathan Summers 11 Jan 20:45
Fab Psycho
2006-01-09 20:45:56 UTC (over 19 years ago)
I'd like to write in a text file from a scm plugin.I didn't see any relevant fx in gimp function browser... Someone could give me a sample source for file opening, writing and closing ?
Best regards, Fabian
Nathan Summers
2006-01-10 18:15:23 UTC (over 19 years ago)
Script-Fu isn't capible of doing this. If you haven't checked out tiny-fu, you probably should.
Rockwalrus
2006-01-10 21:57:45 UTC (over 19 years ago)
"Fab Psycho" writes:
From the SIOD reference:
(fopen path mode)
Opens the file and returns a file stream.
(fwrite data stream)
Write the data, a string or byte-array to the stream. Or data can also be a list of a string or byte-array and a numerical length.
(fclose stream)
Closes the open file stream.
Nathan Summers
2006-01-11 16:25:27 UTC (over 19 years ago)
f
(fopen path mode)
(fclose stream)
Hmm, interesting. I couldn't get this to work with script-fu under 1.2, but it seems to work fine under 2.2.
Rockwalrus
Simon Budig
2006-01-11 17:36:18 UTC (over 19 years ago)
(fopen path mode)
(fclose stream)
Well, it certainly worked 7 years ago: http://www.home.unix-ag.org/simon/gimp/hotspots.html
Bye, Simon
Nathan Summers
2006-01-11 20:45:03 UTC (over 19 years ago)
(fopen path mode)
(fclose stream)
Maybe it was only broken on Windows.
Rockwalrus
