R: Error compiling gimp 2.3.3 with mingw on winxp
R: Error compiling gimp 2.3.3 with mingw on winxp <pmagnoli@systemevolution.it> 15 Sep 14:36
  R: Error compiling gimp 2.3.3 with mingw on winxp michael chang 15 Sep 21:53
2005-09-15 14:36:02 UTC (over 19 years ago)
Hi, thanks for your help, I commented out the #include_next thing in d:/mingw/include/unistd.h (don't know if it is the right way ...) and it compiled fine with:
./configure --disable-print --disable-python --prefix=/d/gimp233
Now, do you know how to make it print in windows? Also is python scripting supported on windows? Best regards
paolo
There must be something broken in your mingw installation. I have never seen that message myself, but some googling leads me to believe it is related to the #include_next directive? Does your unistd.h (the file >d:/mingw/bin/../lib/gcc/mingw32/3.4.2/../../../../include/unistd.h, i.e. d:/mingw/include/unistd.h) on line 13 have an #include_next directive? (That's funny, as I too have gcc 3.4.2, but my unistd.h does not contain any #include_next.)
If you can't find any other solution, my suggestion is removing all of mingw and re-install...
--tml
michael chang
2005-09-15 21:53:14 UTC (over 19 years ago)
You have to be able to compile the files that are compiled when ./configure is run with --enable-print. I believe Gutenprint may help; but I'm not sure (not even close).
AFAIK, It's doable, although it will be easier (afaik, meaning that it might be in the binaries) in the final 2.4 release -- try checking the archives (a success with gimp 2.3.3 + win + python is there somewhere).
