layer grouping
3 of 4 messages available
20050828190138.14DF3123E4@l... 07 Oct 20:24
  layer grouping Szasz Pal 29 Aug 05:24
   layer grouping Leon Brooks 29 Aug 05:55
   layer grouping Øyvind Kolås 02 Sep 16:13
Szasz Pal
2005-08-29 05:24:46 UTC (over 19 years ago)
layer grouping
Hi!
I have an idea for the future versions of gimp: layer grouping. Ie. you could group the layers, and perform some operations on them. Ie. you could toggle visibility, reaise-lower, etc.
I usually make some cartoon like gfx for splash screen (or some other gfx) for games. usually I do this by first drawing the countour lines, then draw solid colors below it (usually a different layer for each colour, so I can change them easily later), and I also have two layers for dark and light shading.
Usually I have other objects in the text (maybe other cartoonish objects/characters, or some simple text, or a logo) which needs again more layers. Hence sometimes the number of layers goes above 20. Layer grouping could help me (and I think other people as well) a lot, because I could quickly switch to work on another character in the same image (ie. turn all other layers invisible), quickly change the order of layers, etc.
What do you think about this idea?
Btw, GIMP RULEZ! It's a great tool. I cannot compare it to photoshop, because I haven't used it, but I think I never will ;-)
Leon Brooks
2005-08-29 05:55:49 UTC (over 19 years ago)
layer grouping
I think it would help to join this and add a comment:
http://bugzilla.gnome.org/show_bug.cgi?id=166938
In general, start here and do a search (I used "layers"):
You need to go to the trouble of examining even bugs that don't seem from the title to be very closely related, because bugs are merged, split and sometimes just wander form their original target into the area you want covered.
It's also a good idea to add comments to related bugs even if you don't expect them to solve your problem because they might get resolved first, and the _way_ they get resolved might help or hinder your quest.
Cheers; Leon
-- http://cyberknights.com.au/ Modern tools; traditional dedication http://plug.linux.org.au/ Member, Perth Linux User Group http://slpwa.asn.au/ Member, Linux Professionals WA http://osia.net.au/ Member, Open Source Industry Australia http://linux.org.au/ Member, Linux Australia
Øyvind Kolås
2005-09-02 16:13:13 UTC (over 19 years ago)
layer grouping
On 8/29/05, Szasz Pal wrote:
Hi!
http://pippin.gimp.org/bauxite/ contains some screenshots of my experiments with regard to extending the layer concept. Keeping some of the possibilities that might arise in the future (the future with GEGL) in mind might pay off when pondering the user interface.
The biggest problem with an advanced layer model, is that the user might get lost.
/pippin
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/
